Кое что о проблемах SRX и других машин GM
Прогуливаясь по инету нашел список решения проблем, известных GM
Например такая табличка
Truck Issues - Fix It Right the First Time
By Blog Post on November 1, 2010 4:57 PM | No Comments
Model Year
Vehicle Line / Condition
Do This
Don't Do This
Reference Information / Bulletin Number
2010-2011
Equinox, Terrain -- Front seat power lumbar support inoperative
Install the revised screwS
Replace the entire lumbar assembly
PI0246
2008-2009
Express, Savana -- Outside power rearview mirrors inoperative
Replace 2 amp fuse with 5 amp fuse and replace power mirror switch
Replace mirrors
09-08-64-031A
2010
Acadia, Avalanche, Enclave, Sierra, Silverado, Suburban, Tahoe, Traverse, Yukon, Yukon Denali, Yukon XL, Yukon XL Denali -- Popping, static noises coming from radio speakers when using iPod as current audio source
For vehicles equipped with radio RPO UUJ exhibiting iPod concerns, update the USB firmware
Replace the radio
PI0239
2010-2011
SRX -- Front fascia lower air dam exhibits poor fit and/or appears mismatched, wavy or gapped to fascia
Adjust the front air dam on the fascia per kit instructions
Charge warranty for the repair
PI0240
2010-2011
SRX -- Front fender inner panel access opening cover chrome trim molding loose or missing
Replace both sides during the service visit
Replace only one side with the missing molding
PI0237
2011
Silverado, Sierra -- Exhaust leak, fuel smell, oily substance on exhaust pipe
Align exhaust pipe to manifold
Replace exhaust or DPF components
PI0235
2010
SRX -- MIL illuminated, hard/no start, water on driver front floor, DTCs set
Replace the fuel tank harness-to-body harness and replace the connector terminals
Replace the body harness
10-08-45-002D
2007-2010
Avalanche, Escalade, Escalade ESV, Escalade EXT, Sierra, Silverado, Suburban, Tahoe -- Poor fit/gap at interface of side door trim panel/lower door or rattle noise upon opening/closing door
Replace panel retainers
Replace door trim panel
PI0040A
2009-2010
Canyon, Cobalt, G5, Sierra, Silverado -- Intermittent MIL/Check Engine light on, DTC P0451 or P0454
Install a fuel tank pressure sensor shield
Replace the fuel tank pressure sensor
10-06-04-001B
2010-2011
SRX -- Revised transfer case rear output shaft seal and installation tool
Use seal installer DT-49954-A (Red in color)
Use seal installer DT-49954 (Blue in color)
PI0225
2010
Equinox, Terrain -- 25 amp J case fuse availability
Replace only the fuse
Replace the entire UBEC for an open 25 amp fuse
PI0222
2010-2011
LaCrosse, SRX -- Remote memory seat recall intermittent operation or inoperative
Replace the driver's seat adjuster memory module and reprogram the module
Replace the key fob module
PI0187A
Желающие поисследовать весь перечень, ищут ссылку на  gmtechlink
А можно ссылку )))) что бы не искать...
Ну почему же, посмотрите справа, там ссылки на ежемесячные бюллютени за 2 года.
SRX  упоминается довольно часто. Из неприятного, не полностью окрашен, имеет место проникновение воды, как слева, так и справа спереди, плохие контакты на массу, плохая сборка помпы подъемника задней двери.
  Зато теперь знаю, что проверить при покупке))
