STS комплектация по VIN. Запросы сюда.
25 минут назад, zverradze сказал:
VR5 (PROVISIONS,SLOW VEHICLE WARNING TRIANGLE MOUNTING); AH8 (ADJUSTER PASS ST POWER,8 WAY); DT4 (ASH RECEPTACLE AND CIGARETTE LIGHTER); VP6 (NOISE LEVEL CONTROL); TB5 (BODY EQUIPMENT LIFT GATE (POWER)); JE5 (BRAKE SYSTEM PWR, ANTILOCK, FRT & RR WHL); JE2 (BRAKE LINING PERFORMANCE DRIVING); EXP (EXPORT - I.E.S. EXPORT I.E.S.); 41U (EXTERIOR COLOR,PRIMARY,BLACK); VH5 (PLATE,VEHICLE IDENTIFICATION(EXPORT)); U30 (CLUSTER INST, TACH, CLOCK); CZ3 (COUNTRY RUSSIA); T62 (LIGHTING DAYTIME RUNNING ----DELETE); KA3 (HEATER ENG BLOCK - 220 VOLT); V08 (COOLING SYSTEM,HEAVY DUTY); NT4 (EMISSION SYSTEM EEC 05); E2C (RAPID DELIVERY SYS CUSTOM ORDERS (E/K-TRK CKST)); R6U (CONTROL SALES ITEM NO. 20); 6SB (COMPONENT-COMPUTER SELECTED,SUSPENSION); K14 (FILTER AIR, AUTO RECIRCULATING); UL2 (RADIO FREQUENCY(EUROPEAN)); 7SB (COMPONENT-COMPUTER SELECTED,SUSPENSION); KG4 (GENERATOR 150 AMP); A26 (WINDOW,UNITED KINGDOM AND EUROPEAN GLAZING(EXPORT)); C3B (ROOF SUN,GLASS,SLIDING,ELEC,TRANSPARENT PLASTIC FIXED); C4R (GVW RATING 6,008 LBS); TT8 (HEADLAMPS HIGH INTENSITY DISCHARGE, RH RULE OF ROAD); TR7 (HEADLAMPS CONTROL LEVELING SYSTEM, AUTOMATIC); U03 (HORN,NOISE REGULATION); AS6 (RESTRAINT HEAD, RR SEAT - DELETE); CJ2 (HVAC SYSTEM AIR CONDITIONER FRT, AUTO TEMP CONT, AUX TEMP CONT); KA1 (HEATER - SEAT); IL2 (TRIM,INTERIOR DESIGN); ARH (NET PET GUARD/LUGGAGE); C57 (VENT,FORCED AIR); UJ9 (INDICATOR, LOW TIRE PRESS,TIRE PRESS MONTORING SYSTEM(TPM)); U2Y (INFOTAINMENT SYSTEM 008); JJD (I/P SUBASSEMBLY NOT INSTALLED (MODULAR OPTIMIZATION METHOD ONLY)); VC5 (LABEL - SHIPPING, EXCEPT US, US POSSESSIONS, OR JAPAN LABEL); VJ2 (LABEL, EXPORT HEADLAMP ADJUST); VL2 (LABEL, SPARE CAUTION, COMPACT SPARE); AU8 (LOCK CONTROL REMOTE ENTRY, SPECIFIC FREQUENCY); PB4 (LOCK KIT,ALUMINUM WHEEL); T79 (LAMPS,REAR FOG); T90 (LAMP,SIGNALING AND MARKER(EXPORT)); N05 (LOCK,FUEL FILLER CAP); VL4 (LICENSE PLATE,FRONT MOUNTING PACKAGE EEC); A45 (MEMORY SEAT ADJUSTER, MIRROR, POWER, DRIVER & ENHANCED MEMORY PERSONALIZATION); DR4 (MIRROR,OUTSIDE,RH AND LH REMOTE CONTROL,ELEC,HTD,LT SENS,POWER FLDG); F55 (CHASSIS CONTINOUSLY VARIABLE REAL TIME DAMPING MAGNETO RHEOLOGICAL); MX7 (MERCHANDISED TRANS AUTO PROVISIONS, O/D, AWD (ALL WHEEL DRIVE)); NDA (NAVIGATION DISC DATA NOT INSTALLED); B19 (ORNAMENTATION,INTERIOR(CUSTOM)); B20 (ORNAMENTATION,INTERIOR(LUXURY)); B57 (ORNAMENTATION,EXTERIOR TRIM(DELUXE)); VH9 (ENVELOPE,OWNER INFORMATION MANUAL); JF4 (PEDALS ADJUSTABLE, POWER); JNG (PROP SHAFT, PAINTED); VG1 (PROTECTOR UNDERHOOD COMPOUND, CORROSION PREVENTIVE, WATER BASED, CLEAR,EXPORT); VG9 (PROTECTOR WAX,EXT BODY(EXPORT)); JJB (PT DRESS SUBASSEMBLY NOT INSTALLED (MODULAR OPTIMIZATION METHOD ONLY)); GU5 (AXLE,REAR,3.23 RATIO); YB6 (AXLE,FRONT(BASE EQUIPMENT)); AX4 (RESTRAINT SYSTEM,FRONT AND REAR SEAT,MANUAL(EUROPEAN)); A82 (RESTRAINT SYSTEM,HEAD(EXPORT)); AY0 (RESTRAINT SYSTEM SEAT, INFLATABLE, DRIVER & PASS, FRT SIDE, ROOF SIDE); 8XX (COMPONENT RR LH - COMPUTER SEL SUSP (8XX)); 9XX (COMPONENT RR RH - COMPUTER SEL SUSP (9XX)); YD6 (SPRING,REAR(BASE EQUIPMENT)); BTV (CONTROL REMOTE ENGINE START); AM0 (SEAT RR FLEXIBLE CONFIGURATION); AT8 (RESTRAINT PROVISIONS CHILD, RR SEAT, RR FACING); AL2 (CONTROL SEAT, POWER LUMBAR); JJL (SUSPENSION FRONT NOT INSTALLED (MODULAR OPTIMIZATION METHOD ONLY)); UC2 (SPEEDOMETER INST, KILO & MILES, KILO ODOMETER, POSITIVE BIAS(EXPORT)); 1SJ (PACKAGE - OPTION 09 OPTION PACKAGE 09 OPTION PACKAGE 09); Y47 (SALES PACKAGE CADILLAC, INTERNATIONAL LUXURY 001); Y49 (SALES PACKAGE CADILLAC, INTERNATIONAL PERFORMANCE 001); Y51 (SALES PACKAGE CADILLAC, INTERNATIONAL SEATING); Y52 (SALES PACKAGE CADILLAC, INTERNATIONAL UTILITY); UQS (SPEAKER SYSTEM PREMIUM AUDIO BRANDED WITH SURROUND AMPLIFIER); YD5 (SPRING,FRONT(BASE EQUIPMENT)); FE3 (SUSPENSION SYSTEM,SPORT); JJM (SUSPENSION REAR NOT INSTALLED (MODULAR OPTIMIZATION METHOD ONLY)); AQ9 (SEAT,FRONT BUCKET,DRIVER,PASSENGER,RECLINING); N31 (STEERING WHEEL HEATED); UTA (THEFT DETERENT SYS THATCHAM ELECTRICAL CONTENT); Q16 (TIRE ALL P235/60R18 FRT & P255/55R18 RR); V76 (HOOK,FRONT TOW); V92 (TRAILER PROVISIONS); 192 (TRIM COMBINATION,BLACK/EBONY LEATHER); 19I (INTERIOR TRIM COLOR BLACK/EBONYINTERIOR TRIM,EBONY); V78 (VEHICLE STATEMENT(DELETE)(EXPORT)); AL0 (SENSOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR); QF8 (WHEEL 18 X 8, ALUMINUM, POLISHED); BAG (PARTS PKG EXPORT); CE4 (WASHER,HEADLAMP,HIGH PRESSURE); XA7 (WASHER NOZZLES, HEATED, WINDSHIELD)
Большое спасибо!
По итогу самоблока не нашел....
  • 7 месяцев спустя...
13.08.2022 в 15:30, Коба сказал:
1G6DW67V180118125
Добрый день, подскажите пожалуйста комплектацию.
заранее спасибо!
1 U.S. BUILT
G GENERAL MOTORS, GENASYS L.C.
6 CADILLAC
DW STS RWD
6 FOUR-DOOR SEDAN (26,29,48,68)
7 ACTIVE (MANUAL) BELTS W/DRIVER & PASSENGER INFLATABLE RESTRAINT - FRONT, SIDE, ROOF, & OCCUPANT SENSOR (AY0 W/SENSOR)
V ENG OPT - LLT DISP - 3.6L CYL - V6 FUEL SYS - SFI DIV - 1,6 PROD IN - U.S.
1 CHECK DIGIT
8 2008 MODEL YEAR
0 LANSING - GRAND RIVER MI
118125 СЕРИЙНЫЙ НОМЕР
192 TRIM COMBINATION,BLACK/EBONY LEATHER
19I INTERIOR TRIM COLOR BLACK/EBONYINTERIOR TRIM,EBONY
1SK PACKAGE - OPTION 10 OPTION PACKAGE #10 OPTION PACKAGE #10
41U EXTERIOR COLOR,PRIMARY,BLACK
6ZK COMPONENT FRT LH COMPUTER SEL SUSP
7ZK COMPONENT FRT RH COMPUTER SEL SUSP (7ZK)
8XT COMPONENT RR LH COMPUTER SEL SUSP (8XT)
9XT COMPONENT RR RH COMPUTER SEL SUSP (9XT)
A26 WINDOW,UNITED KINGDOM AND EUROPEAN GLAZING(EXPORT)
A45 MEMORY SEAT ADJUSTER, MIRROR, POWER, DRIVER & ENHANCED MEMORY PERSONALIZATION
A82 RESTRAINT SYSTEM,HEAD(EXPORT)
AL0 SENSOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR
AL2 CONTROL SEAT, POWER LUMBAR
AP9 NET,CONVENIENCE
AQ9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,RECLINING
AT8 RESTRAINT PROVISIONS CHILD, RR SEAT, RR FACING
AX4 RESTRAINT SYSTEM,FRONT AND REAR SEAT,MANUAL(EUROPEAN)
AY0 RESTRAINT SYSTEM SEAT, INFLATABLE, DRIVER & PASS, FRT SIDE, ROOF SIDE
B20 ORNAMENTATION,INTERIOR(LUXURY)
B57 ORNAMENTATION,EXTERIOR TRIM(DELUXE)
BAG PARTS PKG EXPORT
CE1 WIPER SYSTEM WINDSHIELD, PULSE, MOISTURE SENSITIVE
CE4 WASHER,HEADLAMP,HIGH PRESSURE
CFN ROOF SUN, GLASS, SLIDING, ELEC -- NOT INSTALLED
CJ2 HVAC SYSTEM AIR CONDITIONER FRT, AUTO TEMP CONT, AUX TEMP CONT
CZ3 COUNTRY RUSSIA
DD8 MIRROR,INSIDE,REARVIEW,TILT,AUTOMATIC,LIGHT SENSITIVE
DL7 MIRROR O/S LH & RH, REMOTE CONTROL, ELECTRIC, HEATED POWER FOLDING, COLOR
DT4 ASH RECEPTACLE AND CIGARETTE LIGHTER
EXP EXPORT - I.E.S. EXPORT I.E.S.
FE1 SUSPENSION SYSTEM,SOFT RIDE
G64 SALES PACKAGE PERFORMANCE
G80 AXLE,REAR,POSITRACTION,LIMITED SLIP
GU5 AXLE,REAR,3.23 RATIO
IL2 TRIM,INTERIOR DESIGN
JE5 BRAKE SYSTEM PWR, ANTILOCK, FRT & RR WHL
JJB PT DRESS SUBASSEMBLY NOT INSTALLED (MODULAR OPTIMIZATION METHOD ONLY)
JJD I/P SUBASSEMBLY NOT INSTALLED (MODULAR OPTIMIZATION METHOD ONLY)
JJL SUSPENSION FRONT NOT INSTALLED (MODULAR OPTIMIZATION METHOD ONLY)
JJM SUSPENSION REAR NOT INSTALLED (MODULAR OPTIMIZATION METHOD ONLY)
JNG PROP SHAFT, PAINTED
KA3 HEATER ENG BLOCK - 220 VOLT
KB6 HEATER SEAT, COOLING, FRT
KG4 GENERATOR 150 AMP
LLT ENGINE GAS, 6 CYL, 3.6L, DI, V6, ALUM, 60 DEGREES, HO GM
MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION)
MYB TRANSMISSION AUTO 6 SPD, HMD, 6L-50
N05 LOCK,FUEL FILLER CAP
N31 STEERING WHEEL HEATED
NT4 EMISSION SYSTEM EEC 05
NV7 STEERING,POWER,VARIABLE EFFORT
P40 WHEEL 18 X 8, ALUMINUM, SPORT
PB4 LOCK KIT,ALUMINUM WHEEL
Q12 TIRE ALL P235/50R18 FRT & P255/45R18 RR
R6I CONTROL SALES ITEM NO. 9
T2J ORNAMENTATION,INTERIOR,EXPORT UNIQUE REQUIREMENTS(EXPORT)
T43 SPOILER,REAR
T62 LIGHTING DAYTIME RUNNING ----DELETE
T79 LAMPS,REAR FOG
T90 LAMP,SIGNALING AND MARKER(EXPORT)
TR7 HEADLAMPS CONTROL LEVELING SYSTEM, AUTOMATIC
TT8 HEADLAMPS HIGH INTENSITY DISCHARGE, RH RULE OF ROAD
U03 HORN,NOISE REGULATION
U30 CLUSTER INST, TACH, CLOCK
UA2 THEFT DETERENT SYS EXPORT SPECIFIC
UC2 SPEEDOMETER INST, KILO & MILES, KILO ODOMETER, POSITIVE BIAS(EXPORT)
UHB LOCK CONTROL, ENTRY REMOTE ENTRY PASSIVE, REMOTE START, SPECIFIC FREQUENCY
UJ9 INDICATOR, LOW TIRE PRESS,TIRE PRESS MONTORING SYSTEM(TPM)
UY5 SPEAKER SYSTEM 15, DELUXE
V08 COOLING SYSTEM,HEAVY DUTY
V76 HOOK,FRONT TOW
V78 VEHICLE STATEMENT(DELETE)(EXPORT)
V92 TRAILER PROVISIONS
VC5 LABEL - SHIPPING, EXCEPT US, US POSSESSIONS, OR JAPAN LABEL
VG1 PROTECTOR UNDERHOOD COMPOUND, CORROSION PREVENTIVE, WATER BASED, CLEAR,EXPORT
VG9 PROTECTOR WAX,EXT BODY(EXPORT)
VH5 PLATE,VEHICLE IDENTIFICATION(EXPORT)
VH9 ENVELOPE,OWNER INFORMATION MANUAL
VJ2 LABEL, EXPORT HEADLAMP ADJUST
VL2 LABEL, SPARE CAUTION, COMPACT SPARE
VL4 LICENSE PLATE,FRONT MOUNTING PACKAGE EEC
VP6 NOISE LEVEL CONTROL
VR5 PROVISIONS,SLOW VEHICLE WARNING TRIANGLE MOUNTING
XA7 WASHER NOZZLES, HEATED, WINDSHIELD
Y48 SALES PACKAGE CADILLAC, INTERNATIONAL LUXURY 002
YQ6 INFOTAINMENT SYSTEM 014
  • 10 месяцев спустя...
Здравствуйте, подскажите пожалуйста комплектацию 1G6DC67A870172333 и если есть расшифровка АКПП, и если возможно где найти схему предохранителей , почему то не работают именно " передние " повортники
  • 2 года спустя...
09.10.2025 в 16:49, Begpo_KoT9IT сказал:
Доброго вечера. Надеюсь на вашу помощь. Не нашел как самостоятельно расшировать win. Буду признателен.
3GYFN9E33FS533300
Дата сборки 07-Aug-2014
3 Mexico Built
G General Motors
Y Cadillac MPV
F GVWR 5001-6000, Brake Sys - Hydraulic, Body Style 26
N9 Cadillac SRX Export (Non US, Non Canada)
E Active manual belts, Airbags - Driver & Passenger - Front (1st row), Front Seat Side (1st row), Roof Side (All seating rows)
3 LFX - Engine Gas, 6 CYL, 3.6L, SIDI, DOHC, VVT, E85 MAX, ALUM GM
3 Check Digit
F 2015 Model Year
S Ramos Arizpe Mexico
533300 СЕРИЙНЫЙ НОМЕР
05B TRIM COLOR SEAT CARAMEL TAN
1C8 TRIM COLOR DR PANEL JET BLACK/CARAMEL TAN
1SM PACKAGE - OPTION 12 OPTION PACKAGE #12 OPTION PACKAGE #12
1SZ PACKAGE OPTION2HM MOLDING DOOR INTR RAVEN SAPELE
34G STEERING WHEEL COLOR RAVEN SAPELE
4CW INTERIOR TRIM JET BLACK/CARAMEL TAN
5BS KNOB RAVEN SAPELE
6AA SPRING COMPTR SELECT FRT LH
7AA SPRING COMPTR SELECT FRT RH
8X2 COMPONENT RR LH NON-COMPUTER SEL SUSP
9X2 COMPONENT RR RH NON-COMPUTER SEL SUSP
AAB MEMORY DRIVER CONVENIENCE PACKAGE
AF8 LOCK CONTROL SIDE DOOR, ANTI THEFT PROTECTION
AFE INTERIOR TRIM CONFIG #5
AG2 ADJUSTER PASS ST POWER, MULTI-DIRECTIONALADJUSTER,SEAT,6-WAY POWER,SPLIT BENCH,PASSENGER
ANY EQUIPMENT CARGO RAILS AND TIE DOWNS
AR9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE)
ASV EQUIPMENT SENSOR AIR MOISTURE & W/S TEMP
AXP VIN IDENT POSITION, MULTI- PURPOSE VEHICLE
BTV CONTROL REMOTE ENGINE START
C3U ROOF SUN, GLASS, SLIDING, ELEC, TRANSPARENT GLASS FIXED
C6S GVW RATING 2,520 KG
C99 SWITCH INFL RST I/P MDL MAN SUPPRESSION
CEC WIPER SYSTEM WINDSHIELD, INTERMITTENT, MOISTURE SENSITIVE
CV4 COUNTRY ISRAEL
D42 COVER,REAR COMPARTMENT SECURITY(SHADE)
DR4 MIRROR,OUTSIDE,RH AND LH REMOTE CONTROL,ELEC,HTD,LT SENS,POWER FLDG
EBS TRIM SEAT LEATHER, NUANCE SANDSTONE, MINI-PERF
EPM MODEL CONVERSION-ALL WHEEL DRIVE W/TRANSFER CASE
EWD MIRROR PROVISIONS O/S ETCHED WARNING DELETION
F07 RATIO TRANSAXLE FINAL DRIVE 3.39
F46 CHASSIS ALL WHEEL DRIVE W/TRANSFER CASE
FBJ TRIM DOOR VINYL, SHEFFIELD PROTEIN
FE2 SUSPENSION SYSTEM,RIDE AND HANDLING
FHO VEHICLE FUEL GASOLINE E10
GBR PRIMARY COLOR EXTERIOR, PLATINUM ICE TRI-COAT (G)
I15 ENGINEERING YEAR 2015
JF4 PEDALS ADJUSTABLE, POWER
JJ2 BRAKE LINING BRAKE NOISE AND DUST PERFORMANCE
JJK SUSPENSION REAR INSTALLED (MODULAR OPTIMIZATION METHOD ONLY)
JL9 BRAKE SYSTEM,POWER,FRONT AND REAR DISC,ANTILOCK
KA1 HEATER - SEAT
LFX ENGINE GAS, 6 CYL, 3.6L, SIDI, DOHC, VVT, E85 MAX, ALUM GM
LHD VEHICLE DRIVE LEFTHAND DRIVE
M7U TRANSMISSION AUTO 6 SPD, 6T70, AWD, GEN 2
MBI MARKETING AREA ISRAEL
N08 LOCK CONTROL FUEL FILLER DR, REM CONT
NE9 EMISSION SYSTEM EEC 09
NP5 STEERING WHEEL,LEATHER WRAPPED
PCW CONTROL SALES ITEM NO. 114
QMY TIRE ALL P235/65R18-104H BW TL AL3
R9N CONTROL - SALES ITEM NO. 89
RAO RADIO BASE
RT4 WHEEL 18 X 8.0, J, ALUMINUM, DESIGN 1
RTX WHEEL SPARE 18 X 4.5, B, ALUMINUM, DESIGN 1
SAL PLANT CODE- RAMOS ARIZPE, MEXICO GM DE MEXICO
SLM SALES PROCESSING-STOCK ORDERS
T79 LAMPS,REAR FOG
T84 HEADLAMPS,RH RULE OF THE ROAD,(MARKED E)
T89 LAMP,TAIL AND STOP(EXPORT)
T96 LAMP,FRONT FOG
TB5 BODY EQUIPMENT LIFT GATE (POWER)
TQ5 CONTROL INTELLIGENT HIGH BEAM
TSQ LAMP PACKAGE INTERIOR, DELUXE
U2J DIGITAL AUDIO SYSTEM S-BAND \"NOT INSTALLED\"
UD5 SENSOR INDICATOR PARKING ASSIST
UDD DISPLAY INSTRUMENT DRIVER INFO ENHANCED (MULTI COLOR GRAPHIC)
UEC SENSOR INDICATOR AUTOMATIC AIR RECIRCULATION
UEU SENSOR INDICATOR FORWARD COLLISION ALERT
UFG SENSOR INDICATOR REAR CROSS TRAFFIC ALERT
UFL SENSOR INDICATOR LANE DEPARTURE WARNING
UFT SIDE ACTIVE SAFETY OBSTACLE DETECTION
ULS LOCK CONTROL STEERING COLUMN
UQS SPEAKER SYSTEM PREMIUM AUDIO BRANDED WITH SURROUND AMPLIFIER
UTC THEFT DETERENT SYS THATCHAM ELECTRICAL & MECHANICAL CONTENT
UVC CAMERA REAR VIEW
UY4 DISPLAY NAVIGATION SYSTEM
V64 RAIL ROOF, SILVER
V76 HOOK,FRONT TOW
V83 VEHICLE STATEMENT,ECE ORGANIZATION
VFT PROTECTOR VEHICLE, CORROSION PREVENTIVE
VGP PROTECTOR IMPACT, PEDESTRIAN
VJ4 LABEL, EXPORT CHILD SEAT LOCATION
WJJ PANEL CENTER RAVEN SAPELE
WMF VIN MODEL YEAR 2015
XL8 FREQUENCIES 433 MHZ
ZCD TIRE SPARE T135/70R18 SL 104M BW SPR
