targetSTS
  1. да на обычных: FE1 = SUSPENSION SYSTEM,SOFT RIDE SOFT RIDE SUSP(FE1) это скорее плюс для бу авто
  2. VIN: 1GYEE53A480162244 Год: 2008 Модель: E,6EB26 Дата сборки: 11Jan2008 192 = TRIM COMBINATION,BLACK/EBONY LEATHER LEATHER TRIM(192) 19I = INTERIOR TRIM COLOR BLACK/EBONY INTERIOR TRIM(19I) 1SK = PACKAGE - OPTION 10 OPTION PACKAGE #10 OPTION PACKAGE #10 (1SK) 41U = EXTERIOR COLOR,PRIMARY (41U) 6NC = COMPONENT FRT LH COMPUTER SEL SUSP (6NC) SUSP(6NC) 7NC = COMPONENT FRT RH COMPUTER SEL SUSP (7NC) SUSP(7NC) 8XZ = COMPONENT RR LH - COMPUTER SEL SUSP (8XZ) SUSP(8XZ) 9XZ = COMPONENT RR RH - COMPUTER SEL SUSP (9XZ) SUSP(9XZ) A26 = WINDOW,UNITED KINGDOM AND EUROPEAN GLAZING(EXPORT) EUROPEAN WDO GLAZING(A26)(EXPORT) A45 = MEMORY SEAT ADJUSTER, MIRROR, POWER, DRIVER & ENHANCED MEMORY PERSONALIZATION MEMORY MIR AND ST ADJ(A45) A82 = RESTRAINT SYSTEM,HEAD(EXPORT) HD RST SYS(A82)(EXPORT) AH8 = ADJUSTER PASS ST POWER,8 WAY 8 WAY PWR ST ADJ(AH8) AL0 = SENSOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR FRT PASS/CHILD PRESENCE DETECTOR INFL REST IND SENSOR(AL0) AL2 = CONTROL SEAT, POWER LUMBAR SEAT CTL,PWR LUMBAR(AL2) AQ9 = SEAT,FRONT BUCKET,DRIVER,PASSENGER,RECLINING RECL FRT BKT ST,LUXURY(AQ9) ARH = NET PET GUARD/LUGGAGE PET GUARD/LUGGAGE NET(ARH) AT8 = RESTRAINT PROVISIONS CHILD, RR SEAT, RR FACING RR SEAT RR FACING CHILD RESTRAINT PROVISIONS(AT8) AU8 = LOCK CONTROL REMOTE ENTRY, SPECIFIC FREQUENCY REMOTE ENTRY LK CONT(AU8) AX4 = RESTRAINT SYSTEM,FRONT AND REAR SEAT,MANUAL(EUROPEAN) FRT & RR MAN RST SYS FOR EUROPEAN VEHICLE(AX4) AY0 = RESTRAINT SYSTEM SEAT, INFLATABLE, DRIVER & PASS, FRT SIDE, ROOF SIDE DRVR & PASS FRT SIDE & ROOF INFLATABLE RESTRAINT(AY0) B19 = ORNAMENTATION,INTERIOR(CUSTOM) CUSTOM INTR(B19) B20 = ORNAMENTATION,INTERIOR(LUXURY) LUXURY INTR(B20) B57 = ORNAMENTATION,EXTERIOR TRIM(DELUXE) DELUXE EXTR TR(B57) B70 = PLATE DOOR SILL COVER DOOR SILL CVR PLATE(B70) BAG = PARTS PKG EXPORT PARTS PKG(BAG) BTV = CONTROL REMOTE ENGINE START REMOTE CONTROL ENGINE START(BTV) C4R C57 = VENT,FORCED AIR AIR VENT(C57) CE4 = WASHER,HEADLAMP,HIGH PRESSURE HDLP WA(CE4) CF5 = ROOF,SUN,GLASS SLIDING,ELECTRIC ELEC SUNROOF(GLASS)(CF5) CJ2 = HVAC SYSTEM AIR CONDITIONER FRT, AUTO TEMP CONT, AUX TEMP CONT A/C FRT AUTO/AUX CONT(CJ2) CZ3 = COUNTRY RUSSIA RUSSIA(CZ3) D7E = TRAY LOAD FLOOR, STORAGE LOCKABLE LOAD FLOOR STORAGE TRAY(D7E) DR4 = MIRROR,OUTSIDE,RH AND LH REMOTE CONTROL,ELEC,HTD,LT SENS,POWER FLDG HTD R/CON O/S MIR(DR4) DT4 = ASH RECEPTACLE AND CIGARETTE LIGHTER ASH TRAY & C/LTR(DT4) E2C EXP = EXPORT - I.E.S. EXPORT I.E.S. EXPORT-SPECIFIC MARKET AREA EQUIPMENT(EXP) FE1 = SUSPENSION SYSTEM,SOFT RIDE SOFT RIDE SUSP(FE1) G80 = AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80) GU5 = AXLE,REAR,3.23 RATIO 3.23R(GU5) IL2 = TRIM,INTERIOR DESIGN INTERIOR TRIM DESIGN(IL2) JE2 = BRAKE LINING PERFORMANCE DRIVING PERFORMANCE BRAKE LINING(JE2) JE5 = BRAKE SYSTEM PWR, ANTILOCK, FRT & RR WHL FRT & RR ANTILOCK BRK(JE5) JF4 = PEDALS ADJUSTABLE, POWER PWR ADJ PEDALS(JF4) JJB = PT DRESS SUBASSEMBLY NOT INSTALLED (MODULAR OPTIMIZATION METHOD ONLY) PLANT OPERATION(JJB) JJD = I/P SUBASSEMBLY NOT INSTALLED (MODULAR OPTIMIZATION METHOD ONLY) PLANT OPERATION(JJD) JJL = SUSPENSION FRONT NOT INSTALLED (MODULAR OPTIMIZATION METHOD ONLY) PLANT OPERATION(JJL) JJM = SUSPENSION REAR NOT INSTALLED (MODULAR OPTIMIZATION METHOD ONLY) PLANT OPERATION(JJM) JNG = PROP SHAFT, PAINTED PROP SHF,PAINTED(JNG) K14 = FILTER AIR, AUTO RECIRCULATING AUTO RECRC AIR FILTER(K14) KA1 = HEATER - SEAT ST HTR(KA1) KA3 = HEATER ENG BLOCK - 220 VOLT 220 VOLT ENG BLOCK HTR(KA3) KG4 = GENERATOR 150 AMP 150 AMP GEN(KG4) LH2 = ENGINE GAS, 8 CYL, 4.6L/(281 CID), SFI, V8, DOHC, HO, ALUM, GM 4.6A(LH2) MX7 = MERCHANDISED TRANS AUTO PROVISIONS, O/D, AWD (ALL WHEEL DRIVE) AWD AUTO TRANS PROVISIONS(MX7) MYB = TRANSMISSION AUTO 6 SPD, HMD, 6L-50 6-SPD AUTO TRANS(MYB) N05 = LOCK,FUEL FILLER CAP FUEL FIL LKG CAP(N05) N31 = STEERING WHEEL HEATED HTD STRG WHL(N31) NDA = NAVIGATION DISC DATA NOT INSTALLED NAV DISC DATA NOT INSTALLED(NDA) NDB = EXHAUST DUAL, ROUND, CHROME, VISIBLE DUAL EXH(NDB) NT4 = EMISSION SYSTEM EEC 05 EEC 05 EMIS(NT4) PB4 = LOCK KIT,ALUMINUM WHEEL AL WHL LOCK KIT(PB4) QUB = TIRE ALL P255/50R20-104V BW TL AL3 TIRE(QUB) QW3 = WHEEL 20 X 8, ALUMINUM, FLANGELESS, PREMIUM ALUM WHL(QW3) R1T R6U T62 = LIGHTING DAYTIME RUNNING ----DELETE T62) T79 = LAMPS,REAR FOG RR FOG LP(T79) T90 = LAMP,SIGNALING AND MARKER(EXPORT) SIGNAL & MARKER LAMP(T90) TB5 = BODY EQUIPMENT LIFT GATE (POWER) PWR LIFT GATE(TB5) TL4 = GRILLE,PAINTED PAINTED GRL(TL4) TR7 = HEADLAMPS CONTROL LEVELING SYSTEM, AUTOMATIC AUTO HDLP LVL SYS(TR7) TT8 = HEADLAMPS HIGH INTENSITY DISCHARGE, RH RULE OF ROAD HDLP,HI INTENS DISCHARGE,RH RULE OF ROAD(TT8) U03 = HORN,NOISE REGULATION NOISE REGULATION HORN(U03) U2Y = INFOTAINMENT SYSTEM 008 INFOTAINMENT SYSTEM 008(U2Y) U30 = CLUSTER INST, TACH, CLOCK CLUSTER(U30) UC2 = SPEEDOMETER INST, KILO & MILES, KILO ODOMETER, POSITIVE BIAS(EXPORT) KILO & MILES POSITIVE BIAS SPEEDO(UC2) UJ9 = INDICATOR, LOW TIRE PRESS,TIRE PRESS MONTORING SYSTEM(TPM) LOW TIRE PRESS MONITORING SYS IND(UJ9) UL2 = RADIO FREQUENCY(EUROPEAN) EUROPEAN RDO FREQ(UL2) UQS = SPEAKER SYSTEM PREMIUM AUDIO BRANDED WITH SURROUND AMPLIFIER PREMIUM SPKR SYS W/SURROUND AMP(UQS) UTA = THEFT DETERENT SYS THATCHAM ELECTRICAL CONTENT THEFT DETERENT SYS ELEC CONTENT(UTA) V08 = COOLING SYSTEM,HEAVY DUTY HVY DUTY CLG(V08) V4V = MODEL CONVERSION, SRX V8 SRX V8(V4V) V55 = CARRIER,ROOF LUGGAGE(CHROME) CHROME RF LUGG CARR(V55) V76 = HOOK,FRONT TOW FRT TOW HOOK(V76) V78 = VEHICLE STATEMENT(DELETE)(EXPORT) V78)VEHICLE STATEMENT-DELETE V92 = TRAILER PROVISIONS TRLR PROVISIONS(V92) VC5 = LABEL - SHIPPING, EXCEPT US, US POSSESSIONS, OR JAPAN LABEL SHIPPING LABEL USED OUTSIDE U.S. AND JAPAN(VC5) VD9 = FASCIA FRT & RR, BODY COLOR BODY COLOR FASCIAS(VD9) VG1 = PROTECTOR UNDERHOOD COMPOUND, CORROSION PREVENTIVE, WATER BASED, CLEAR,EXPORT CLEAR UNDERHOOD CORROSION PREVENTIVE(VG1) VG9 = PROTECTOR WAX,EXT BODY(EXPORT) PROTECTIVE BODY WAX(VG9) VH5 = PLATE,VEHICLE IDENTIFICATION(EXPORT) VEH ID PLT(VH5) VH9 = ENVELOPE,OWNER INFORMATION MANUAL OWNER INFO MAN ENV(VH9) VJ2 = LABEL, EXPORT HEADLAMP ADJUST HEADLAMP ADJUST LABEL FOR EXPORT(VJ2) VL2 = LABEL, SPARE CAUTION, COMPACT SPARE COMPACT SPA TIRE LABEL(VL2) VL4 = LICENSE PLATE,FRONT MOUNTING PACKAGE EEC FRT LIC PLT MTG PKG FOR EEC(VL4) VP6 = NOISE LEVEL CONTROL NOISE LVL CONT(VP6) VR5 = PROVISIONS,SLOW VEHICLE WARNING TRIANGLE MOUNTING SLOW VEH WARNING MOUNT PROVISIONS(VR5) XA7 = WASHER NOZZLES, HEATED, WINDSHIELD HTD W/S NOZ(XA7) Y47 = SALES PACKAGE CADILLAC, INTERNATIONAL LUXURY 001 CADILLAC INTERNATIONAL LUXURY 001 PKG(Y47) Y49 = SALES PACKAGE CADILLAC, INTERNATIONAL PERFORMANCE 001 CADILLAC INTERNATIONAL PERFORMANCE 001 PKG(Y49) Y51 = SALES PACKAGE CADILLAC, INTERNATIONAL SEATING CADILLAC INTERNATIONAL SEATING PKG(Y91) YB6 YD5 = SPRING,FRONT(BASE EQUIPMENT) FRT SPRING(YD5) YD6 = SPRING,REAR(BASE EQUIPMENT) RR SPRING(YD6)
  3. Так пиши американский вин, без него нечего и говорить
  4. для вашей работы возможно. меня для диагностики моей машины вполне устраивает. Хотя бесспорно тек2 устарел еще лет 10 назад
  5. да слыхал... а эта скорость нужна при диагностике? к тому же это еще ноут таскай с собой)) MDI нужен, если есть необходимость и более свежие машины смотреть....а допустим я смотрю теком в основном только STS, пару раз смотрел cts2\srx2\tahoe как куплю ATS сразу придется брать MDI
  6. для STS лучше tech2
  7. лампе 100 лет
  8. Какая ступица стояла и сколько прошла?
  9. targetSTS
    Цепи ГРМ только NorthStar
    подниму не знаю где вы смотрите, но на 2005 STS 4.6 именно так как я написал
  10. редуктор передний например
  11. targetSTS
    Датчик расхода воздуха
    номера обоих датчиков я тебе написал уже
  12. targetSTS
    MAF: 12567377 SENSOR, MASS AIRFLOW (ACDelco #213-1594) E26 (LH2) MAP: 12614973 SENSOR, MAP (INCLS SEAL) (INCLS 741) (MATING CONN W/LEADS USE 88987997) (ACDelco #213-796) первый это расходомер воздуха на трубе, второй давления воздуха на впускном коллекторе
  13. targetSTS
    дай вин посмотрю
  14. по моему рановато. как я писал в другой теме - к тысячам 200 желательно поменять. тем более на 2007 у вас уже более новый нордстар по сравнению с 05-06
  15. targetSTS
    надо смотреть что показывают оба датчика а р0102 это маф в первую очередь, но перед тем как менять - фильтр, разъем на маф все внимательно посмотреть. Может где подсос воздуха идет?
  16. странно вообще как-то сравнивать заднеприводный седан и переднеприводный крос. разница как небо и земля
  17. targetSTS
    Как долить масло в АКПП?
    прочитать ошибки (ваш кэп). масло не причем скорее всего и не дольешь его
  18. targetSTS
    Тест драйв, первые впечатления.
    к моменту выхода xt5 было 2 варианта или ставить старую 6-ступку или брать новее на стороне. старую ставить на такую модель нельзя..... у джиэм только сейчас появилась новая коробка под переднеприводные платформы - новая 10ступка. я думаю при рестайле заменят а обзор для девочек этот)))
  19. targetSTS
    Оригинальный монитор
    можно только порадоваться за тебя удачи с продажей STS и покупкой эск4
  20. да это все бред
  21. не знаю, что такое qx60, но в конкурентах х5\каен\q7\gl.
  22. как раз наоборот, топовые кросовер должен быть на заднеприводной омеге xt7\xt9. А все остальне классом ниже да скорее всего на переднем. А на xt7\9 также как и на ct6 вскоре будет вэ8, но не атмосферник
  23. мое мнение - это просто какие-то старые рисунки не более.
  24. targetSTS
    Проскачила цепь?
    Так надо понять почему так произошло. Менять надо при пробеге около 200 тыщ. Может там с натяжением или еще с чем косяк...Лучше менять конечно раз уж полезли
