парктроники чтоле задние?
или у нас есть функция мёртвых зон по бокам???? никогда не слышал
Датчики не парктроника, там свои датчики стоят вроде как в заднем бампере
Нужно их точное место нахождение, дабы внедрить...хочу SBZA внедрить, все компоненты имеются
Object Detection Description and Operation (Side Blind Zone Alert)
The side blind zone alert (SBZA) system is designed to detect vehicles or other objects that may be located in the vehicles blind spots. This detection is performed by two side object sensors, located behind the rear fascia on each side of the vehicle. When an object is detected in a blind spot, an indicator in the outside rearview mirror will illuminate, notifying the driver that it is unsafe to change lanes.
The SBZA system is made up of the following components:
• Left side object sensor
• Right side object sensor
• Driver door module
• Passenger door module
• Driver outside rearview mirror
• Passenger outside rearview mirror
Side Object Sensors
The side object sensors are each located behind the rear fascia, positioned so that the sensor is pointing out toward the opposite lane. Each sensor is supplied B+ and ground. The right sensor receives an additional ground. Both sensors communicate independently on the serial data line. The serial data enters the right sensor in a pass-thru configuration, the connects to the left sensor. The scan tool is able to individually communicate with each sensor.
When a vehicle or object is detected by a side object sensor, a serial data message is sent to the appropriate door module to illuminate the indicator located in the outside rearview mirror.
Door Modules
The driver and passenger receive serial data messages from the side object sensors. When a message is received indicating that a vehicle or object is in the blind spot, the appropriate door module will apply voltage to the indicator located in the outside rearview mirror, illuminating the indicator. The door module provides a continuous low reference circuit for the indicator.
Outside Rearview Mirror
The outside rearview mirrors each contain an indicator that is controlled by the appropriate door module. This indicator is illuminated when a vehicle or object is position in the vehicle's blind spot.
Side Blind Zone Alert Operation
When the vehicle is started, the indicators located in the outside rearview mirror will briefly illuminate to indicate that the system is operating. The side object sensors cover a zone of approximately one lane over from both sides of the vehicle, 11 ft. or 3.5 m. This zone starts at each side mirror and goes back approximately 16 ft. (5.0 m). The height of the zone is approximately between 1.5 ft. (0.5 m) and 6 ft. (2.0 m) off the ground. When a vehicle or object is detected in this area, the appropriate indicator will be illuminated, indicating to the driver that it is unsafe to change lanes. If a turn signal is activated while the indicator is illuminated, the indicator will flash as a more urgent warning that a lane change may be unsafe.
Foul weather may affect the operation of the SBZA system. Occasional missed alerts can occur under normal circumstances and will increase in wet conditions. The number of missed alerts will increase with increased rainfall or road spray. Heavy rainfall, as well as mud, dirt, snow, ice, or slush build-up on the rear fascia, will completely disable the system.
If the vehicle is towing a trailer or has an object, such as a bicycle rack, attached to the rear of the vehicle, the SBZA system may not function properly and the indicators will remain illuminated at all time.
Да мне бы поточнее или хотя бы есть там какие приливы на задней стороне бампера?
Никаких. Бампер стандартный и никакого отношения к Side Blind Zone Alert не имеет.
Микроволновые радары стоят на отдельных кронштейнах под бампером с креплением на кузов.
Сами собой не заработают. 1)Требуются НОВЫЕ датчики, переписать VIN Вы в них не сможете. А без соответствия VIN кое-каким другим блоками оно не работает. 2) Нужно менять программное во многих других блоках для работы Side Blind Zone Alert.
Тоесть если датчик умер его заменить нельзя?!
Вообще это ваще видение ситуации;)))
Можно. На новый. Для авто 2009 модельного возможно и б/у. Но только для 2009 MY и все. Для всех других MY программного НЕТ, нечем перепрограммировать  ;D
Ну или изобретайте флешер для переписи VIN в EEPROM этих блоков. Я такого не нашел готового  ;D
