Купил б.у. Магнитоллу для ЭСК 3, пишет заблокирована от кражи
Купил б.у. Магнитоллу для ЭСК 3 с ебэя, вчера поставили в "ЛАККИ" магнитолла пишет заблокирована от кражи.  Пытались перепрошиться - не получилось. Куда ехать и сколько это удовольствие будет стОить?
а вот еще инструкция: проверь, сработает ли!!!
GM DELCO THEFTLOCK RADIO UNLOCK CODE:
1. Press and hold presets 2 and 3 for about 5 to 10 seconds until you
get 3 digits on your display. This is the first 3 of 6 digits you will
need, so write 'em down.
2. After doing step one and writing down the code, immediately press
the
AM/FM button to get the last 3 of the 6 numbers you'll need, and write
'em down. (if you wait too long between steps 1 and 2 and the LOC code
displays again, just start over).
3. Call this number, it's a prerecorded message, so don't worry about
having to talk to anyone...1-800-537-5140. The voice will ask if
you're
calling for Chevy, Pontiac, Cadillac, etc... When you here him tell
you
to press "2" for Pontiac, press 206010 and hit the # key. He'll ask
you
for the 6 digit code that you've written down. Enter that and press
the
* key. He will then give you a code, and the option to get additional
4
digit codes, but one should be sufficient.
4. Follow the normal procedure in your owners manual for unlocking the
radio with your new code...press the hour set button on your radio
until
you get the first two numbers of the code, then press the minute set
button until you've entered the last two numbers. Immediately press
the
AM/FM button once the correct code is entered and the code SEC or
"secured" will be displayed on the display screen. Now, just turn the
radio on, and your ready to roll.
There is an additional step you can take to remove all codes from the
radio and start from scratch by entering your own personalized 4 digit
code so that it won't get you in a pickle again! Just repeat step 4
and
you should get a display screen that reads ---. This means the code is
out, and you can now program your own code. Of course, once you
receive
the 4 digit code from the GM recorded message, just keep it in a safe
place, because you can use that same code again and again should you
have any more problems with it in the future. Good luck, and yes, it
does work.
ток что позвонил, проверил номер - работает, и реально автоответчик...
Илья, где машина стоит? если в Лакки, то давай попробуем решить ;)
Саня, у меня руки из.... э..... ну не полезу я туда :) вынуть могу, отнести могу, пиши куда :) ?  СПАСИБО!
не надо ничего никуда носить )) пока, по крайней мере..
08. Евгений сказал что к официалам надо ехать. Я  позвонил официалам, они говорят, что если пишет такую надпись, значит не сделали какую то процедуру при ДЕинсталяции магнитоллы в штатах. И теперь типа перепрошивка не заработает :(
ну. допущу, что они могут быть правы, потому что:
http://www.justanswer.com/cadillac/3imdv-navigation-radio-theftlocked-activated-unlock.html
надо еще поковырять, что делать именно с нави-юнитами.. но там смысл в том. что в бошке сидит вин и он сверяется с вином боди, и если они не совпадают (как в твоем случае) то усё :(- тогда только использовать кулхацкерский сопосб со вскрытием, как в ролике выше
вот еще здесь почитать про проблему:
http://www.cadillacforums.com/forums/cadillac-audio-video-security-systems/146771-07-escalade-theftlock-problem-please-help.html
у тебя ж раньше НЕ НАВИ юнит был, так??
какой партнамбер был и какой купил сейчас, на замену?
вот еще:
Subject:Radio Displays Locked Or Theft Lock - keywords inoperative loc no sound speaker volume #PIT4007B - (07/19/2007)
Models:2007-2008 Cadillac Escalade, ESV, EXT
2007-2008 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2007-2008 GMC Sierra, Yukon, Yukon Denali, Yukon XL, Yukon Denali XL
This PI was superseded to update model years and Recommendation/Instructions. Please discard PIT4007A.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
The radio theft deterrent system disables functionality if the VIN information received by the radio does not match the vehicle VIN information. The radio receives the vehicle VIN information through GMLAN. If a radio is replaced or swapped from another vehicle the radio will need to relearn the VIN information from the vehicle before it will function. If the VIN information of the vehicle does not match the learned VIN information in the radio, it will display "LOCKED" or "THEFT LOCK".
Reccomendation/Correction:
Currently, performing the radio setup in SI (Document ID # 1745049) will not learn the vehicles VIN information to the new radio. Engineering is aware of this and working on a correction.
A temporary solution is to perform the radio setup in SI (Document ID# 1745049), as well as, perform a VIN relearn. To perform the VIN relearn, build the Tech 2 as follows:
F0: Diagnostics
2006
Passenger Car
(1) Chevrolet
W
WN Monte Carlo LTZ
F6: Body and Accessories
Entertainment
F5: Module Setup
F0: Radio
F0: VIN Relearn
The Tech 2 will ask you if you would like to erase the theft data: "select yes"
Shut key off for 60 second and remove Tech 2 from vehicle.
VIN should relearn on start up.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
Не скажу :( и старая и новая сейчас в ЛАКИ. :( Вот думаю с чего начать?
начать с того, что взять и вдумчиво прочитать (как я только что) все то, что по ссылкам ;)
а потом действовать!
смысл, вкратце, в том, что бошка не может "переучить вин", и поэтому, после собсно привязки радио техом (что и делал женя, видимо), надо еще выполнить следующее:
F0: Diagnostics
2006
Passenger Car
(1) Chevrolet
W
WN Monte Carlo LTZ
Entertainment
F5: Module Setup
F0: Radio
F0: VIN Relearn
Я предпологаю, что просто у него оборудование не "тянет"... Сегодня обзвоню официалов. Мож кто возьмется...
бред ;) оборудование у всех одинаковое ))))
ИМХО напрямую к официалам, 100%.
Там сбрасывается частота (на неснятом мафоне - ч/з диагностич.разъём), и мафон приписывается к новому вину сам при первом же включении.
Но там ещё нужно будет прошивать мафон под твою комплектацию (есть потолочный монитор / нет потолочного;) и ставить еврочастоты на FM. Это тоже всё ч/з диагностический р-м без снятия. Дилер в помощь. Ну или мож КЭ...
Так будет всегда, если ставить другой мафон.
Обратись сюда: http://erta.ru
думаю помогут.
эти могут помочь толтко внедрить колхоз вместо штатки и содрать дофига.
Я,лет 5 назад обращался к ним,с подобной проблемой,только на Х5. Если память не изменяет,около 100$ отдавал за раскодировку. Ща х/з,может всё поменялось.
  • 3 месяца спустя...
Интересно, чем закончилось, отремонтировали или нет? У меня год не работают диски, вдруг перестал читать DVD, пишет ДИСК ЭРРОР - думаю засорилась голова, тк. я радио всегда только слушаю, а тут жена попросила дивиди глянуть.
Ремонт в erta.ru 9т.р. + запчасти, позвонил сейчас. А вот новые на ебеях вполне ничего по стоимости, и не все пишут что разлочены. Поэтому, публике бы знать, справились ОД или любая другая контора, смогли спарить новую магнитолу топикстартеру?
