AleMar
General Member
    111
  1. ток что позвонил, проверил номер - работает, и реально автоответчик... Илья, где машина стоит? если в Лакки, то давай попробуем решить
  2. а вот еще инструкция: проверь, сработает ли!!! GM DELCO THEFTLOCK RADIO UNLOCK CODE: 1. Press and hold presets 2 and 3 for about 5 to 10 seconds until you get 3 digits on your display. This is the first 3 of 6 digits you will need, so write 'em down. 2. After doing step one and writing down the code, immediately press the AM/FM button to get the last 3 of the 6 numbers you'll need, and write 'em down. (if you wait too long between steps 1 and 2 and the LOC code displays again, just start over). 3. Call this number, it's a prerecorded message, so don't worry about having to talk to anyone...1-800-537-5140. The voice will ask if you're calling for Chevy, Pontiac, Cadillac, etc... When you here him tell you to press "2" for Pontiac, press 206010 and hit the # key. He'll ask you for the 6 digit code that you've written down. Enter that and press the * key. He will then give you a code, and the option to get additional 4 digit codes, but one should be sufficient. 4. Follow the normal procedure in your owners manual for unlocking the radio with your new code...press the hour set button on your radio until you get the first two numbers of the code, then press the minute set button until you've entered the last two numbers. Immediately press the AM/FM button once the correct code is entered and the code SEC or "secured" will be displayed on the display screen. Now, just turn the radio on, and your ready to roll. There is an additional step you can take to remove all codes from the radio and start from scratch by entering your own personalized 4 digit code so that it won't get you in a pickle again! Just repeat step 4 and you should get a display screen that reads ---. This means the code is out, and you can now program your own code. Of course, once you receive the 4 digit code from the GM recorded message, just keep it in a safe place, because you can use that same code again and again should you have any more problems with it in the future. Good luck, and yes, it does work.
  3. вот, например: понятно, куда идти? ))
  4. копать форумы ща, погоди..
  5. а он автоматом включается при минусовой температуре? по каким параметрам срабатывает и как реализован, Вань?
  6. плюсик тебе за оперативность )
  7. дружище, заполни профиль, уточни год.
  8. подсох надо раскидывать проводку, там где жгут, чистить и брызгать клеммы и все такое, как выше советовали (в коннекторе гниют, бывает, контакты). и быть все равно готовым к скорой смерти крайних парктроников - это расходник )) закидывает туда грязюку, конструктивно так или лезть-корячиться и чистить их и заливать герметиком нах
  9. AleMar
    CTS II помогите оценить
    забить и быть готовым чуть скинуть цену. или прожечь бак 98-го, может, каталик просрется на время
  10. ну вот, скоро и узнаем ))) хотя, думаю,проблем с ней будет не больше, чем с обычной системой.. будет экран чуть подлагивать до прогрева и все..
  11. а ни как!!! ты же не можешь её отключить в режиме R!? её можно отрубить только в "головном" или DIP. по другому я не знаю как Ну так о чем я и говорю!!!))))))) а как, стесняюсь спросить, в это время с башкой общаться? Ток с кнопок на руле, что ли )))) а как настройки аудио поменять, например? Короче, странный выбор имхо
  12. Нене, если скорость меньше 10, как она выключалась?
  13. Ну, мы, похоже, чуть про разный функционал говорим А как она вырубалась?
  14. По просьбе форумчан создаю и закрепляю эту тему. В двух словах: тут все про новый СUE (Сadillac User Experience) от нашего любимого GM Делимся опытом, советуем, жалуемся, радуемся - все здесь.
  15. хха про это можно сразу забыть потому что для этого надо раскорячивать всю систему целиком (ОС) - никто этим не занимался, да и вряд ли это стоит того к тому же, все равно это выглядит убого - на каком языке не пиши ))))
  16. прекрасный опыт! осталось только понять, как сделать так, чтобы все наконец-то нормально заработало )))))) а с мануалом, на, не парься сначала это изучи: http://coastaletech.com/GMX560.htm - как я и говорил, камеру можно настроить через меню, а не свитчами - они для боковых камер и прочей пижни, прежде всего потом - это: http://coastaletech.com/media/GMX560%20Instructions.pdf - инструкция от 560-го, но пофик. если хочешь - 550-го файл по интернетам за минуту находится Александр, привет! всё конечно хорошо, если у него именно это устройство!!! у меня "приблуда" коробочкой похожа, но по факту по настройкам отличается. просто через DIP верняк, по схемам многих подобных устройств я видел что настройки одинаковые! ну, ее в 90 процентах ставили на эск, если человек говорит именно про локпик, как таковой.. был еще какой-то олдскульный, одно время его по дешевке продавали, но на нашем рынке я такой в принципе не встречал... а с дипсвичом вот какая штука: получается, что если его типа переключить, то девайс ВСЕГДА будет транслировать куда-то заднюю камеру... куда? в АУКС?! скорее всего, именно туда.. иначе невозможно пользоваться экраном башки во всех режимах, потому что там картинка с камеры ))) а если в аукс - то там тоже всегда картинка и это тоже лажа, потому что не подключишь ничего другого (например, приставку)... короче - самый вменяемый вариант делать это через софт-меню. Так собсно, и сделано )) через то, которое в 550-м с кнопок на руле реализовано...
  17. а зачем тебе блин этот провод-то у тебя ж сигнал через шину идет! и девайс твой в шине висит!
  18. AleMar
    Опрос: Клубные Рамки
    НУ, как я понимаю, все за рельефные, в основном ))
  19. презентация устройства так же подчистил тему от флуда всем заинтересованным - комм не в ЛС, будем согласовывать установку. Поскольку мне надо изначально выкупить партию устройств - пока по предоплате... но быстро, меньше недели! Presentation_in_Russian_.pdf
  20. да и зачем? )))) что там переводить-то??))) DVD, FM, AUX ))))))
  21. она тупая, не хочет учиться, как типичный второгодник )))
  22. стайлинг хааарррош! единственное, с такой ценой он его будет продавать столько, что уже успеет и второй дом построить ))) ну, если только кто-нить на грузовик кирпича рискнет поменять )))
  23. AleMar
    Диск навигации GM
    нет, нет и нет ждите в следующем поколении
  24. прекрасный опыт! осталось только понять, как сделать так, чтобы все наконец-то нормально заработало )))))) а с мануалом, на, не парься сначала это изучи: http://coastaletech.com/GMX560.htm - как я и говорил, камеру можно настроить через меню, а не свитчами - они для боковых камер и прочей пижни, прежде всего потом - это: http://coastaletech.com/media/GMX560%20Instructions.pdf - инструкция от 560-го, но пофик. если хочешь - 550-го файл по интернетам за минуту находится
  25. привет! у меня это было как ГЛЮК быстренько решил вопрос переключением DIP. о. кстати! посоветуй КУЗЕ, он тут с локпиком мучается.. залез в него, что-то там понапереключал, теперь вернуться к исходному не может, а у меня времени нет ему в мануале нужные строчки разыскивать, да еще и переводить... КУЗЯ: вот добрый-предобрый, отзывчивый форумчанин! он поможет!! )))))
