КУДЫНАС
Jr. Member
О КУДЫНАС
  • День рождения 15.08.1981
    Санкт-Петербург
  • Настоящее имя
    Сергей
  • Телефон
    +79111ОО5О6О
    TAHOE GMT900 LTZ
    2008
  • Гос. номер
    РО3ОРН178
  • VIN
    1GNFK13J18J243358
  • Drive2
    https://www.drive2.ru/r/chevrolet/tahoe/523171273069568218/
6 255 просмотров профиля
КУДЫНАС's Achievements
5
  1. Дата сборки 07-Aug-2014 3 Mexico Built G General Motors Y Cadillac MPV F GVWR 5001-6000, Brake Sys - Hydraulic, Body Style 26 N9 Cadillac SRX Export (Non US, Non Canada) E Active manual belts, Airbags - Driver & Passenger - Front (1st row), Front Seat Side (1st row), Roof Side (All seating rows) 3 LFX - Engine Gas, 6 CYL, 3.6L, SIDI, DOHC, VVT, E85 MAX, ALUM GM 3 Check Digit F 2015 Model Year S Ramos Arizpe Mexico 533300 СЕРИЙНЫЙ НОМЕР 05B TRIM COLOR SEAT CARAMEL TAN 1C8 TRIM COLOR DR PANEL JET BLACK/CARAMEL TAN 1SM PACKAGE - OPTION 12 OPTION PACKAGE #12 OPTION PACKAGE #12 1SZ PACKAGE OPTION2HM MOLDING DOOR INTR RAVEN SAPELE 34G STEERING WHEEL COLOR RAVEN SAPELE 4CW INTERIOR TRIM JET BLACK/CARAMEL TAN 5BS KNOB RAVEN SAPELE 6AA SPRING COMPTR SELECT FRT LH 7AA SPRING COMPTR SELECT FRT RH 8X2 COMPONENT RR LH NON-COMPUTER SEL SUSP 9X2 COMPONENT RR RH NON-COMPUTER SEL SUSP AAB MEMORY DRIVER CONVENIENCE PACKAGE AF8 LOCK CONTROL SIDE DOOR, ANTI THEFT PROTECTION AFE INTERIOR TRIM CONFIG #5 AG2 ADJUSTER PASS ST POWER, MULTI-DIRECTIONALADJUSTER,SEAT,6-WAY POWER,SPLIT BENCH,PASSENGER AL2 CONTROL SEAT, POWER LUMBAR ANY EQUIPMENT CARGO RAILS AND TIE DOWNS AR9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) ASV EQUIPMENT SENSOR AIR MOISTURE & W/S TEMP AX4 RESTRAINT SYSTEM,FRONT AND REAR SEAT,MANUAL(EUROPEAN) AXP VIN IDENT POSITION, MULTI- PURPOSE VEHICLE AY0 RESTRAINT SYSTEM SEAT, INFLATABLE, DRIVER & PASS, FRT SIDE, ROOF SIDE B57 ORNAMENTATION,EXTERIOR TRIM(DELUXE) BAG PARTS PKG EXPORT BTV CONTROL REMOTE ENGINE START C3U ROOF SUN, GLASS, SLIDING, ELEC, TRANSPARENT GLASS FIXED C6S GVW RATING 2,520 KG C99 SWITCH INFL RST I/P MDL MAN SUPPRESSION CE4 WASHER,HEADLAMP,HIGH PRESSURE CEC WIPER SYSTEM WINDSHIELD, INTERMITTENT, MOISTURE SENSITIVE CJ2 HVAC SYSTEM AIR CONDITIONER FRT, AUTO TEMP CONT, AUX TEMP CONT CV4 COUNTRY ISRAEL D42 COVER,REAR COMPARTMENT SECURITY(SHADE) DD8 MIRROR,INSIDE,REARVIEW,TILT,AUTOMATIC,LIGHT SENSITIVE DR4 MIRROR,OUTSIDE,RH AND LH REMOTE CONTROL,ELEC,HTD,LT SENS,POWER FLDG DT4 ASH RECEPTACLE AND CIGARETTE LIGHTER EBS TRIM SEAT LEATHER, NUANCE SANDSTONE, MINI-PERF EPM MODEL CONVERSION-ALL WHEEL DRIVE W/TRANSFER CASE EWD MIRROR PROVISIONS O/S ETCHED WARNING DELETION EXP EXPORT - I.E.S. EXPORT I.E.S. F07 RATIO TRANSAXLE FINAL DRIVE 3.39 F46 CHASSIS ALL WHEEL DRIVE W/TRANSFER CASE FBJ TRIM DOOR VINYL, SHEFFIELD PROTEIN FE2 SUSPENSION SYSTEM,RIDE AND HANDLING FHO VEHICLE FUEL GASOLINE E10 GBR PRIMARY COLOR EXTERIOR, PLATINUM ICE TRI-COAT (G) I15 ENGINEERING YEAR 2015 JF4 PEDALS ADJUSTABLE, POWER JJ2 BRAKE LINING BRAKE NOISE AND DUST PERFORMANCE JJK SUSPENSION REAR INSTALLED (MODULAR OPTIMIZATION METHOD ONLY) JL9 BRAKE SYSTEM,POWER,FRONT AND REAR DISC,ANTILOCK KA1 HEATER - SEAT LFX ENGINE GAS, 6 CYL, 3.6L, SIDI, DOHC, VVT, E85 MAX, ALUM GM LHD VEHICLE DRIVE LEFTHAND DRIVE M7U TRANSMISSION AUTO 6 SPD, 6T70, AWD, GEN 2 MBI MARKETING AREA ISRAEL N08 LOCK CONTROL FUEL FILLER DR, REM CONT NE9 EMISSION SYSTEM EEC 09 NP5 STEERING WHEEL,LEATHER WRAPPED PB4 LOCK KIT,ALUMINUM WHEEL PCW CONTROL SALES ITEM NO. 114 QMY TIRE ALL P235/65R18-104H BW TL AL3 R9N CONTROL - SALES ITEM NO. 89 RAO RADIO BASE RT4 WHEEL 18 X 8.0, J, ALUMINUM, DESIGN 1 RTX WHEEL SPARE 18 X 4.5, B, ALUMINUM, DESIGN 1 SAL PLANT CODE- RAMOS ARIZPE, MEXICO GM DE MEXICO SLM SALES PROCESSING-STOCK ORDERS T79 LAMPS,REAR FOG T84 HEADLAMPS,RH RULE OF THE ROAD,(MARKED E) T89 LAMP,TAIL AND STOP(EXPORT) T90 LAMP,SIGNALING AND MARKER(EXPORT) T96 LAMP,FRONT FOG TB5 BODY EQUIPMENT LIFT GATE (POWER) TQ5 CONTROL INTELLIGENT HIGH BEAM TSQ LAMP PACKAGE INTERIOR, DELUXE U03 HORN,NOISE REGULATION U2J DIGITAL AUDIO SYSTEM S-BAND \"NOT INSTALLED\" UC2 SPEEDOMETER INST, KILO & MILES, KILO ODOMETER, POSITIVE BIAS(EXPORT) UD5 SENSOR INDICATOR PARKING ASSIST UDD DISPLAY INSTRUMENT DRIVER INFO ENHANCED (MULTI COLOR GRAPHIC) UEC SENSOR INDICATOR AUTOMATIC AIR RECIRCULATION UEU SENSOR INDICATOR FORWARD COLLISION ALERT UFG SENSOR INDICATOR REAR CROSS TRAFFIC ALERT UFL SENSOR INDICATOR LANE DEPARTURE WARNING UFT SIDE ACTIVE SAFETY OBSTACLE DETECTION ULS LOCK CONTROL STEERING COLUMN UQS SPEAKER SYSTEM PREMIUM AUDIO BRANDED WITH SURROUND AMPLIFIER UTC THEFT DETERENT SYS THATCHAM ELECTRICAL & MECHANICAL CONTENT UVC CAMERA REAR VIEW UY4 DISPLAY NAVIGATION SYSTEM V64 RAIL ROOF, SILVER V76 HOOK,FRONT TOW V83 VEHICLE STATEMENT,ECE ORGANIZATION VC5 LABEL - SHIPPING, EXCEPT US, US POSSESSIONS, OR JAPAN LABEL VFT PROTECTOR VEHICLE, CORROSION PREVENTIVE VGP PROTECTOR IMPACT, PEDESTRIAN VH9 ENVELOPE,OWNER INFORMATION MANUAL VJ2 LABEL, EXPORT HEADLAMP ADJUST VJ4 LABEL, EXPORT CHILD SEAT LOCATION VL2 LABEL, SPARE CAUTION, COMPACT SPARE VL4 LICENSE PLATE,FRONT MOUNTING PACKAGE EEC VP6 NOISE LEVEL CONTROL VR5 PROVISIONS,SLOW VEHICLE WARNING TRIANGLE MOUNTING WJJ PANEL CENTER RAVEN SAPELE WMF VIN MODEL YEAR 2015 XL8 FREQUENCIES 433 MHZ ZCD TIRE SPARE T135/70R18 SL 104M BW SPR
  2. https://www.drive2.ru/l/523188590377698797/ Это завод, шли для Эски, но ставятся и на Таху. С производства сняты давно, больше не купить.
  3. 1 U.S. BUILT G GENERAL MOTORS, GENASYS L.C. 6 CADILLAC DW STS RWD 6 FOUR-DOOR SEDAN (26,29,48,68) 7 ACTIVE (MANUAL) BELTS W/DRIVER & PASSENGER INFLATABLE RESTRAINT - FRONT, SIDE, ROOF, & OCCUPANT SENSOR (AY0 W/SENSOR) V ENG OPT - LLT DISP - 3.6L CYL - V6 FUEL SYS - SFI DIV - 1,6 PROD IN - U.S. 1 CHECK DIGIT 8 2008 MODEL YEAR 0 LANSING - GRAND RIVER MI 118125 СЕРИЙНЫЙ НОМЕР 192 TRIM COMBINATION,BLACK/EBONY LEATHER 19I INTERIOR TRIM COLOR BLACK/EBONYINTERIOR TRIM,EBONY 1SK PACKAGE - OPTION 10 OPTION PACKAGE #10 OPTION PACKAGE #10 41U EXTERIOR COLOR,PRIMARY,BLACK 6ZK COMPONENT FRT LH COMPUTER SEL SUSP 7ZK COMPONENT FRT RH COMPUTER SEL SUSP (7ZK) 8XT COMPONENT RR LH COMPUTER SEL SUSP (8XT) 9XT COMPONENT RR RH COMPUTER SEL SUSP (9XT) A26 WINDOW,UNITED KINGDOM AND EUROPEAN GLAZING(EXPORT) A45 MEMORY SEAT ADJUSTER, MIRROR, POWER, DRIVER & ENHANCED MEMORY PERSONALIZATION A82 RESTRAINT SYSTEM,HEAD(EXPORT) AL0 SENSOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR AL2 CONTROL SEAT, POWER LUMBAR AP9 NET,CONVENIENCE AQ9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,RECLINING AT8 RESTRAINT PROVISIONS CHILD, RR SEAT, RR FACING AX4 RESTRAINT SYSTEM,FRONT AND REAR SEAT,MANUAL(EUROPEAN) AY0 RESTRAINT SYSTEM SEAT, INFLATABLE, DRIVER & PASS, FRT SIDE, ROOF SIDE B20 ORNAMENTATION,INTERIOR(LUXURY) B57 ORNAMENTATION,EXTERIOR TRIM(DELUXE) BAG PARTS PKG EXPORT CE1 WIPER SYSTEM WINDSHIELD, PULSE, MOISTURE SENSITIVE CE4 WASHER,HEADLAMP,HIGH PRESSURE CFN ROOF SUN, GLASS, SLIDING, ELEC -- NOT INSTALLED CJ2 HVAC SYSTEM AIR CONDITIONER FRT, AUTO TEMP CONT, AUX TEMP CONT CZ3 COUNTRY RUSSIA DD8 MIRROR,INSIDE,REARVIEW,TILT,AUTOMATIC,LIGHT SENSITIVE DL7 MIRROR O/S LH & RH, REMOTE CONTROL, ELECTRIC, HEATED POWER FOLDING, COLOR DT4 ASH RECEPTACLE AND CIGARETTE LIGHTER EXP EXPORT - I.E.S. EXPORT I.E.S. FE1 SUSPENSION SYSTEM,SOFT RIDE G64 SALES PACKAGE PERFORMANCE G80 AXLE,REAR,POSITRACTION,LIMITED SLIP GU5 AXLE,REAR,3.23 RATIO IL2 TRIM,INTERIOR DESIGN JE5 BRAKE SYSTEM PWR, ANTILOCK, FRT & RR WHL JJB PT DRESS SUBASSEMBLY NOT INSTALLED (MODULAR OPTIMIZATION METHOD ONLY) JJD I/P SUBASSEMBLY NOT INSTALLED (MODULAR OPTIMIZATION METHOD ONLY) JJL SUSPENSION FRONT NOT INSTALLED (MODULAR OPTIMIZATION METHOD ONLY) JJM SUSPENSION REAR NOT INSTALLED (MODULAR OPTIMIZATION METHOD ONLY) JNG PROP SHAFT, PAINTED KA3 HEATER ENG BLOCK - 220 VOLT KB6 HEATER SEAT, COOLING, FRT KG4 GENERATOR 150 AMP LLT ENGINE GAS, 6 CYL, 3.6L, DI, V6, ALUM, 60 DEGREES, HO GM MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) MYB TRANSMISSION AUTO 6 SPD, HMD, 6L-50 N05 LOCK,FUEL FILLER CAP N31 STEERING WHEEL HEATED NT4 EMISSION SYSTEM EEC 05 NV7 STEERING,POWER,VARIABLE EFFORT P40 WHEEL 18 X 8, ALUMINUM, SPORT PB4 LOCK KIT,ALUMINUM WHEEL Q12 TIRE ALL P235/50R18 FRT & P255/45R18 RR R6I CONTROL SALES ITEM NO. 9 T2J ORNAMENTATION,INTERIOR,EXPORT UNIQUE REQUIREMENTS(EXPORT) T43 SPOILER,REAR T62 LIGHTING DAYTIME RUNNING ----DELETE T79 LAMPS,REAR FOG T90 LAMP,SIGNALING AND MARKER(EXPORT) TR7 HEADLAMPS CONTROL LEVELING SYSTEM, AUTOMATIC TT8 HEADLAMPS HIGH INTENSITY DISCHARGE, RH RULE OF ROAD U03 HORN,NOISE REGULATION U30 CLUSTER INST, TACH, CLOCK UA2 THEFT DETERENT SYS EXPORT SPECIFIC UC2 SPEEDOMETER INST, KILO & MILES, KILO ODOMETER, POSITIVE BIAS(EXPORT) UHB LOCK CONTROL, ENTRY REMOTE ENTRY PASSIVE, REMOTE START, SPECIFIC FREQUENCY UJ9 INDICATOR, LOW TIRE PRESS,TIRE PRESS MONTORING SYSTEM(TPM) UY5 SPEAKER SYSTEM 15, DELUXE V08 COOLING SYSTEM,HEAVY DUTY V76 HOOK,FRONT TOW V78 VEHICLE STATEMENT(DELETE)(EXPORT) V92 TRAILER PROVISIONS VC5 LABEL - SHIPPING, EXCEPT US, US POSSESSIONS, OR JAPAN LABEL VG1 PROTECTOR UNDERHOOD COMPOUND, CORROSION PREVENTIVE, WATER BASED, CLEAR,EXPORT VG9 PROTECTOR WAX,EXT BODY(EXPORT) VH5 PLATE,VEHICLE IDENTIFICATION(EXPORT) VH9 ENVELOPE,OWNER INFORMATION MANUAL VJ2 LABEL, EXPORT HEADLAMP ADJUST VL2 LABEL, SPARE CAUTION, COMPACT SPARE VL4 LICENSE PLATE,FRONT MOUNTING PACKAGE EEC VP6 NOISE LEVEL CONTROL VR5 PROVISIONS,SLOW VEHICLE WARNING TRIANGLE MOUNTING XA7 WASHER NOZZLES, HEATED, WINDSHIELD Y48 SALES PACKAGE CADILLAC, INTERNATIONAL LUXURY 002 YQ6 INFOTAINMENT SYSTEM 014
  4. WA 316N
  5. КУДЫНАС
    Как определить модель двс cts cupe
    Самое простое и правильное - открыть авто по VIN номеру в проге, там всё будет написано.
  6. VIN:3GYFN9EY2BS666930 Build Date: 10-Jun-2011 3 Mexico Built G General Motors Y Cadillac MPV F GVWR 5001-6000, Brake Sys - Hydraulic, Body Style 26 N9 Cadillac SRX (Export Only) E Active manual belts, Airbags - Driver & Passenger - Front (1st row), Front Seat Side (1st row), Roof Side (All seating rows) Y LF1 - Engine Gas, 6 CYL, 3.0L, SIDI, DOHC, VVT, ALUM 2 Check Digit B 2011 Model Year S Ramos Arizpe Mexico 666930 СЕРИЙНЫЙ НОМЕР 01F TRIM COLOR SEAT SHALE 1AG TRIM COLOR DR PANEL SHALE 1SK PACKAGE - OPTION 10 OPTION PACKAGE #10 OPTION PACKAGE #10 1SZ PACKAGE OPTION- 2BX MOLDING DOOR INTR CHOCO SAPELE 44F STEERING WHEEL COLOR CHOCO SAPELE 4A5 INTERIOR TRIM JET BLACK/SHALE 5AD KNOB CHOCO SAPELE 6AB SPRING COMPTR SELECT FRT LH 7AB SPRING COMPTR SEL FRT RH 8X2 COMPONENT RR LH NON-COMPUTER SEL SUSP 9X2 COMPONENT RR RH NON-COMPUTER SEL SUSP AAB MEMORY DRIVER CONVENIENCE PACKAGE AF8 LOCK CONTROL SIDE DOOR, ANTI THEFT PROTECTION AFE INTERIOR TRIM CONFIG #5 AG2 ADJUSTER PASS ST POWER, MULTI-DIRECTIONALADJUSTER,SEAT,6-WAY POWER,SPLIT BENCH,PASSENGER AL2 CONTROL SEAT, POWER LUMBAR ANY EQUIPMENT CARGO RAILS AND TIE DOWNS AR9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) ARH NET PET GUARD/LUGGAGE ASV EQUIPMENT SENSOR AIR MOISTURE & W/S TEMP ATH LOCK CONTROL, ENTRY REMOTE ENTRY, EXTENDED RANGE, PASSIVE ENTRY AX4 RESTRAINT SYSTEM,FRONT AND REAR SEAT,MANUAL(EUROPEAN) AXX VEHICLE TYPE VEHICLE TYPE - NOT REQUIRED AY0 RESTRAINT SYSTEM SEAT, INFLATABLE, DRIVER & PASS, FRT SIDE, ROOF SIDE B57 ORNAMENTATION,EXTERIOR TRIM(DELUXE) BAG PARTS PKG EXPORT BTV CONTROL REMOTE ENGINE START C3U ROOF SUN, GLASS, SLIDING, ELEC, TRANSPARENT GLASS FIXED C6S GVW RATING 2,520 KG C99 SWITCH INFL RST I/P MDL MAN SUPPRESSION CE4 WASHER,HEADLAMP,HIGH PRESSURE CEC WIPER SYSTEM WINDSHIELD, INTERMITTENT, MOISTURE SENSITIVE CJ4 HVAC SYSTEM AIR CONDITIONING, FRT & RR ELECTRONIC CONTROLS CZ3 COUNTRY RUSSIA D42 COVER,REAR COMPARTMENT SECURITY(SHADE) DD8 MIRROR,INSIDE,REARVIEW,TILT,AUTOMATIC,LIGHT SENSITIVE DR4 MIRROR,OUTSIDE,RH AND LH REMOTE CONTROL,ELEC,HTD,LT SENS,POWER FLDG DT4 ASH RECEPTACLE AND CIGARETTE LIGHTER E2C RAPID DELIVERY SYS CUSTOM ORDERS (E/K-TRK CKST) EBS TRIM SEAT LEATHER, NUANCE SANDSTONE, MINI-PERF EPM MODEL CONVERSION-ALL WHEEL DRIVE W/TRANSFER CASE EWD MIRROR PROVISIONS O/S ETCHED WARNING DELETION EXP EXPORT - I.E.S. EXPORT I.E.S. F07 RATIO TRANSAXLE FINAL DRIVE 3.39 F45 CHASSIS CONTINUOUS VALVE REAL TIME DAMPING F46 CHASSIS ALL WHEEL DRIVE W/TRANSFER CASE FBJ TRIM DOOR VINYL, SHEFFIELD PROTEIN FE3 SUSPENSION SYSTEM,SPORT GHA PRIMARY COLOR EXTERIOR, MAGNA STEEL MET JF4 PEDALS ADJUSTABLE, POWER JJ2 BRAKE LINING BRAKE NOISE AND DUST PERFORMANCE JJK SUSPENSION REAR INSTALLED (MODULAR OPTIMIZATION METHOD ONLY) JL9 BRAKE SYSTEM,POWER,FRONT AND REAR DISC,ANTILOCK KA1 HEATER - SEAT KA6 HEATER,RR SEAT KG4 GENERATOR 150 AMP KU1 FAN SEAT, DRIVER KU3 FAN SEAT, PASS LF1 ENGINE GAS, 6 CYL, 3.0L, SIDI, DOHC, VVT, ALUM, GM LHD VEHICLE DRIVE LEFTHAND DRIVE MH4 TRANSMISSION AUTO 6 SPD, HMD, 6T70, AWD/PTU N08 LOCK CONTROL FUEL FILLER DR, REM CONT NE9 EMISSION SYSTEM EEC 09 NP5 STEERING WHEEL,LEATHER WRAPPED NV7 STEERING,POWER,VARIABLE EFFORT P47 WHEEL 20 X 8.0, ALUMINUM, CHROMED PB4 LOCK KIT,ALUMINUM WHEEL QRX TIRE ALL P235/55R20 102H BW TL AL3 R9N CONTROL - SALES ITEM NO. 89 SAL PLANT CODE- RAMOS ARIZPE, MEXICO GM DE MEXICO SLL SALES PROCESSING-SOLD ORDERS T79 LAMPS,REAR FOG T89 LAMP,TAIL AND STOP(EXPORT) T96 LAMP,FRONT FOG TB5 BODY EQUIPMENT LIFT GATE (POWER) TSQ LAMP PACKAGE INTERIOR, DELUXE TT8 HEADLAMPS HIGH INTENSITY DISCHARGE, RH RULE OF ROAD U03 HORN,NOISE REGULATION U30 CLUSTER INST, TACH, CLOCK U44 RADIO AM/FM STEREO, NAV, DVD-ROM, CAF, HDD, USB RSA, RSE(RUSSIA) U4G TRAILER PROVISIONS HEAVY DUTY U70 DISPLAY DRIVER INFO CENTER (ENHANCED) UC2 SPEEDOMETER INST, KILO & MILES, KILO ODOMETER, POSITIVE BIAS(EXPORT) UD5 SENSOR INDICATOR PARKING ASSIST UEC SENSOR INDICATOR AUTOMATIC AIR RECIRCULATION UL2 RADIO FREQUENCY(EUROPEAN) ULD AUDIO CONTROL RR SEAT & EARPHONE JACKS, DISPLAY ULS LOCK CONTROL STEERING COLUMN UPJ WIRELESS INTERFACE SHORT RANGE, VOICE REC, SMS, EMBEDDED PHONE UQS SPEAKER SYSTEM PREMIUM AUDIO BRANDED WITH SURROUND AMPLIFIER UTC THEFT DETERENT SYS THATCHAM ELECTRICAL & MECHANICAL CONTENT UVC CAMERA REAR VIEW UWG ENTERTAINMENT PKG RR SEAT, INDIVIDUAL PLAY DVD, DUAL HEADREST MONITOR V64 RAIL ROOF, SILVER V76 HOOK,FRONT TOW V78 VEHICLE STATEMENT(DELETE)(EXPORT) VC5 LABEL - SHIPPING, EXCEPT US, US POSSESSIONS, OR JAPAN LABEL VDZ INDICATOR HAZARD WARNING, AUTOMATIC ACTIVATION VFT PROTECTOR VEHICLE, CORROSION PREVENTIVE VGP PROTECTOR IMPACT, PEDESTRIAN VH9 ENVELOPE,OWNER INFORMATION MANUAL VJ2 LABEL, EXPORT HEADLAMP ADJUST VJ4 LABEL, EXPORT CHILD SEAT LOCATION VL2 LABEL, SPARE CAUTION, COMPACT SPARE VL4 LICENSE PLATE,FRONT MOUNTING PACKAGE EEC VP6 NOISE LEVEL CONTROL VR5 PROVISIONS,SLOW VEHICLE WARNING TRIANGLE MOUNTING VVO PANEL CENTER CHOCO SAPELE XL8 FREQUENCIES 433 MHZ ZAA TIRE,COMPACT SPARE 10 Engine Assembly BCT BPB 50 Instrument Cluster BC 7897 61 Transmission BCT 1NCK 65 Rear Axle Assembly BCT 9895 86 Powertrain/Vehicle Control Module (PCM/VCM) BCT AA4G 87 Body Control Module PNT 0198 92 Brake Pressure Modulator PNT 2525 AB SIR Module Assembly - Steering Wheel Inflator BCT 5226 AH SIR Sensor Assembly - Left PNT 2577 AJ SIR Sensor Assembly - Right PNT 2577 AL SIR Module Assembly - Passenger Inflator BCT 0747 AS SIR Sensing Diagnostic Module (SDM) PNT 4893 AT SIR Right Side-Impact Sensing Module PNT 2577 AU SIR Left Side-Impact Sensing Module PNT 2577 CB Sequence Numbers (Flex) Body Assembly Area or Energy Storage System (Veh/Year specific) T 2ZZ CC Sequence Numbers (Flex) Body Assembly Area T 2WW CF Sequence Numbers (Flex) Paint Process Area T 2RR CM Sequence Numbers (Flex) General Assembly Area T 2PP CP Sequence Numbers (Flex) General Assembly Area T 2CC DF SIR LH Roof Rail Mounted Airbag PNT 1354 DG SIR RH Roof Rail Mounted Airbag PNT 1353
  7. VIN 1G6DC67A750234284 Год 2005 Build Date 24-May-2005 Модель D,6DW29 1 U.S. BUILT G GENERAL MOTORS, GENASYS L.C. 6 CADILLAC DC STS V8 6 FOUR-DOOR SEDAN (26,29,48,68) 7 ACTIVE (MANUAL) BELTS W/DRIVER & PASSENGER INFLATABLE RESTRAINTS (FRONTAL & SIDE). REAR PASSENGER INFLATABLE RESTRAINTS (SIDE) A ENG OPT - LH2 DISP - 4.6L CYL - V8 FUEL SYS - SFI DIV - 6 PROD IN - U.S. 7 CHECK DIGIT 5 2005 MODEL YEAR 0 LANSING - GRAND RIVER MI 234284 СЕРИЙНЫЙ НОМЕР 132 TRIM COMBINATION,LEATHER,GRAYTRIM COMBINATION,LEATHER,VERY DK PEWTER W/LT GRAY 13I INTERIOR TRIM,LT GRAYINTERIOR TRIM,LT SMOKE GRAY 1SK PACKAGE - OPTION 10 OPTION PACKAGE #10 OPTION PACKAGE #10 41U EXTERIOR COLOR,PRIMARY,BLACK 6SD COMPONENT-COMPUTER SELECTED SUSP 7SD COMPONENT-COMPUTER SEL SUSP 8HJ COMPONENT- RR LH COMPUTER SEL SUSP (8HJ) 9HJ COMPONENT- RR RH COMPUTER SEL SUSP (9HJ) A26 WINDOW,UNITED KINGDOM AND EUROPEAN GLAZING(EXPORT) A45 MEMORY SEAT ADJUSTER, MIRROR, POWER, DRIVER & ENHANCED MEMORY PERSONALIZATION A82 RESTRAINT SYSTEM,HEAD(EXPORT) AL2 CONTROL SEAT, POWER LUMBAR AP9 NET,CONVENIENCE AQ9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,RECLINING AU8 LOCK CONTROL REMOTE ENTRY, SPECIFIC FREQUENCY AX4 RESTRAINT SYSTEM,FRONT AND REAR SEAT,MANUAL(EUROPEAN) AY0 RESTRAINT SYSTEM SEAT, INFLATABLE, DRIVER & PASS, FRT SIDE, ROOF SIDE B20 ORNAMENTATION,INTERIOR(LUXURY) B57 ORNAMENTATION,EXTERIOR TRIM(DELUXE) BAG PARTS PKG EXPORT CE1 WIPER SYSTEM WINDSHIELD, PULSE, MOISTURE SENSITIVE CE4 WASHER,HEADLAMP,HIGH PRESSURE CJ2 HVAC SYSTEM AIR CONDITIONER FRT, AUTO TEMP CONT, AUX TEMP CONT CZ3 COUNTRY RUSSIA DD8 MIRROR,INSIDE,REARVIEW,TILT,AUTOMATIC,LIGHT SENSITIVE DL7 MIRROR O/S LH & RH, REMOTE CONTROL, ELECTRIC, HEATED POWER FOLDING, COLOR DT4 ASH RECEPTACLE AND CIGARETTE LIGHTER EXP EXPORT - I.E.S. EXPORT I.E.S. F55 CHASSIS CONTINOUSLY VARIABLE REAL TIME DAMPING MAGNETO RHEOLOGICAL FE3 SUSPENSION SYSTEM,SPORT GU5 AXLE,REAR,3.23 RATIO IL2 TRIM,INTERIOR DESIGN JE5 BRAKE SYSTEM PWR, ANTILOCK, FRT & RR WHL JJA PT DRESS SUBASSEMBLY INSTALLED (MODULAR OPTIMIZATION METHOD ONLY) JNG PROP SHAFT, PAINTED K14 FILTER AIR, AUTO RECIRCULATING KA1 HEATER - SEAT KA3 HEATER ENG BLOCK - 220 VOLT KG4 GENERATOR 150 AMP LH2 ENGINE GAS, 8 CYL, 4.6L/(281 CID), SFI, V8, DOHC, HO, ALUM, GM MV3 TRANSMISSION AUTO 5 SPD, HMD, 5L50-E PTU , ELECTRONIC, O/D N05 LOCK,FUEL FILLER CAP N31 STEERING WHEEL HEATED N87 WHEEL 18 X 8, ALUMINUM NT4 EMISSION SYSTEM EEC 05 NV7 STEERING,POWER,VARIABLE EFFORT Q12 TIRE ALL P235/50R18 FRT & P255/45R18 RR R6A CONTROL-SALES ITEM NO. 1 R7K CONTROL SALES ITEM NO. 36 T43 SPOILER,REAR T62 LIGHTING DAYTIME RUNNING ----DELETE T79 LAMPS,REAR FOG TR7 HEADLAMPS CONTROL LEVELING SYSTEM, AUTOMATIC TT8 HEADLAMPS HIGH INTENSITY DISCHARGE, RH RULE OF ROAD U19 SPEEDOMETER,INSTRUMENT,KILOMETERS PER HOUR U30 CLUSTER INST, TACH, CLOCK UA2 THEFT DETERENT SYS EXPORT SPECIFIC UJ9 INDICATOR, LOW TIRE PRESS,TIRE PRESS MONTORING SYSTEM(TPM) UX8 SPEAKER SYSTEM 8, DELUXESPEAKER SYSTEM 8, DUAL F/D MTD, DUAL RR DRS, DUAL MIRROR PATCH CTR I/P, PKG SHELF, AMPLIFIER V08 COOLING SYSTEM,HEAVY DUTY V4X MODEL CONVERSION GMX295, STS V8 V76 HOOK,FRONT TOW V78 VEHICLE STATEMENT(DELETE)(EXPORT) V92 TRAILER PROVISIONS VC5 LABEL - SHIPPING, EXCEPT US, US POSSESSIONS, OR JAPAN LABEL VH5 PLATE,VEHICLE IDENTIFICATION(EXPORT) VJ2 LABEL, EXPORT HEADLAMP ADJUST VJ4 LABEL, EXPORT CHILD SEAT LOCATION VL2 LABEL, SPARE CAUTION, COMPACT SPARE VL4 LICENSE PLATE,FRONT MOUNTING PACKAGE EEC VP6 NOISE LEVEL CONTROL VR5 PROVISIONS,SLOW VEHICLE WARNING TRIANGLE MOUNTING XA7 WASHER NOZZLES, HEATED, WINDSHIELD YQ2 INFOTAINMENT SYSTEM 010
  8. VIN: 1G6DW67V480121746 Build Date: 14-Sep-2007 1 U.S. BUILT G GENERAL MOTORS, GENASYS L.C. 6 CADILLAC DW STS RWD 6 FOUR-DOOR SEDAN (26,29,48,68) 7 ACTIVE (MANUAL) BELTS W/DRIVER & PASSENGER INFLATABLE RESTRAINT - FRONT, SIDE, ROOF, & OCCUPANT SENSOR (AY0 W/SENSOR) V ENG OPT - LLT DISP - 3.6L CYL - V6 FUEL SYS - SFI DIV - 1,6 PROD IN - U.S. 4 CHECK DIGIT 8 2008 MODEL YEAR 0 LANSING - GRAND RIVER MI; SHANGHAI CHINA 121746 СЕРИЙНЫЙ НОМЕР 192 TRIM COMBINATION,BLACK/EBONY LEATHER 19I INTERIOR TRIM COLOR BLACK/EBONYINTERIOR TRIM,EBONY 1SK PACKAGE - OPTION 10 OPTION PACKAGE #10 OPTION PACKAGE #10 67U EXTERIOR COLOR,LT TARNISHED SILVER MET (04)EXTERIOR COLOR,PRIMARY 6ZK COMPONENT FRT LH COMPUTER SEL SUSP 7ZK COMPONENT FRT RH COMPUTER SEL SUSP (7ZK) 8XT COMPONENT RR LH COMPUTER SEL SUSP (8XT) 9XT COMPONENT RR RH COMPUTER SEL SUSP (9XT) A26 WINDOW,UNITED KINGDOM AND EUROPEAN GLAZING(EXPORT) A45 MEMORY SEAT ADJUSTER, MIRROR, POWER, DRIVER & ENHANCED MEMORY PERSONALIZATION A82 RESTRAINT SYSTEM,HEAD(EXPORT) AL0 SENSOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR AL2 CONTROL SEAT, POWER LUMBAR AP9 NET,CONVENIENCE AQ9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,RECLINING AT8 RESTRAINT PROVISIONS CHILD, RR SEAT, RR FACING AX4 RESTRAINT SYSTEM,FRONT AND REAR SEAT,MANUAL(EUROPEAN) AY0 RESTRAINT SYSTEM SEAT, INFLATABLE, DRIVER & PASS, FRT SIDE, ROOF SIDE B20 ORNAMENTATION,INTERIOR(LUXURY) B57 ORNAMENTATION,EXTERIOR TRIM(DELUXE) BAG PARTS PKG EXPORT CE1 WIPER SYSTEM WINDSHIELD, PULSE, MOISTURE SENSITIVE CE4 WASHER,HEADLAMP,HIGH PRESSURE CFN ROOF SUN, GLASS, SLIDING, ELEC -- NOT INSTALLED CJ2 HVAC SYSTEM AIR CONDITIONER FRT, AUTO TEMP CONT, AUX TEMP CONT CZ3 COUNTRY RUSSIA DD8 MIRROR,INSIDE,REARVIEW,TILT,AUTOMATIC,LIGHT SENSITIVE DL7 MIRROR O/S LH & RH, REMOTE CONTROL, ELECTRIC, HEATED POWER FOLDING, COLOR DT4 ASH RECEPTACLE AND CIGARETTE LIGHTER EXP EXPORT - I.E.S. EXPORT I.E.S. FE1 SUSPENSION SYSTEM,SOFT RIDE G64 SALES PACKAGE PERFORMANCE G80 AXLE,REAR,POSITRACTION,LIMITED SLIP GU5 AXLE,REAR,3.23 RATIO IL2 TRIM,INTERIOR DESIGN JE5 BRAKE SYSTEM PWR, ANTILOCK, FRT & RR WHL JJB PT DRESS SUBASSEMBLY NOT INSTALLED (MODULAR OPTIMIZATION METHOD ONLY) JJD I/P SUBASSEMBLY NOT INSTALLED (MODULAR OPTIMIZATION METHOD ONLY) JJL SUSPENSION FRONT NOT INSTALLED (MODULAR OPTIMIZATION METHOD ONLY) JJM SUSPENSION REAR NOT INSTALLED (MODULAR OPTIMIZATION METHOD ONLY) JNG PROP SHAFT, PAINTED K14 FILTER AIR, AUTO RECIRCULATING KA3 HEATER ENG BLOCK - 220 VOLT KB6 HEATER SEAT, COOLING, FRT KG4 GENERATOR 150 AMP LLT ENGINE GAS, 6 CYL, 3.6L, DI, V6, ALUM, 60 DEGREES, HO GM MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) MYB TRANSMISSION AUTO 6 SPD, HMD, 6L-50 N05 LOCK,FUEL FILLER CAP N31 STEERING WHEEL HEATED NT4 EMISSION SYSTEM EEC 05 NV7 STEERING,POWER,VARIABLE EFFORT P40 WHEEL 18 X 8, ALUMINUM, SPORT PB4 LOCK KIT,ALUMINUM WHEEL Q12 TIRE ALL P235/50R18 FRT & P255/45R18 RR R6I CONTROL SALES ITEM NO. 9 T2J ORNAMENTATION,INTERIOR,EXPORT UNIQUE REQUIREMENTS(EXPORT) T43 SPOILER,REAR T62 LIGHTING DAYTIME RUNNING ----DELETE T79 LAMPS,REAR FOG T90 LAMP,SIGNALING AND MARKER(EXPORT) TR7 HEADLAMPS CONTROL LEVELING SYSTEM, AUTOMATIC TT8 HEADLAMPS HIGH INTENSITY DISCHARGE, RH RULE OF ROAD U03 HORN,NOISE REGULATION U30 CLUSTER INST, TACH, CLOCK UA2 THEFT DETERENT SYS EXPORT SPECIFIC UC2 SPEEDOMETER INST, KILO & MILES, KILO ODOMETER, POSITIVE BIAS(EXPORT) UHB LOCK CONTROL, ENTRY REMOTE ENTRY PASSIVE, REMOTE START, SPECIFIC FREQUENCY UJ9 INDICATOR, LOW TIRE PRESS,TIRE PRESS MONTORING SYSTEM(TPM) UY5 SPEAKER SYSTEM 15, DELUXE V08 COOLING SYSTEM,HEAVY DUTY V76 HOOK,FRONT TOW V78 VEHICLE STATEMENT(DELETE)(EXPORT) V92 TRAILER PROVISIONS VC5 LABEL - SHIPPING, EXCEPT US, US POSSESSIONS, OR JAPAN LABEL VG1 PROTECTOR UNDERHOOD COMPOUND, CORROSION PREVENTIVE, WATER BASED, CLEAR,EXPORT VG9 PROTECTOR WAX,EXT BODY(EXPORT) VH5 PLATE,VEHICLE IDENTIFICATION(EXPORT) VH9 ENVELOPE,OWNER INFORMATION MANUAL VJ2 LABEL, EXPORT HEADLAMP ADJUST VL2 LABEL, SPARE CAUTION, COMPACT SPARE VL4 LICENSE PLATE,FRONT MOUNTING PACKAGE EEC VP6 NOISE LEVEL CONTROL VR5 PROVISIONS,SLOW VEHICLE WARNING TRIANGLE MOUNTING XA7 WASHER NOZZLES, HEATED, WINDSHIELD Y48 SALES PACKAGE CADILLAC, INTERNATIONAL LUXURY 002 YQ6 INFOTAINMENT SYSTEM 014 CB Sequence Numbers (Flex) Body Assembly Area or Energy Storage System (Veh/Year specific) T 1ZZ CE Sequence Numbers (Flex) Body Assembly Area T 1PP CP Sequence Numbers (Flex) General Assembly Area T 1GA
  9. VIN:1G6DC67A450233481 Build Date: 20-May-2005 1 U.S. BUILT G GENERAL MOTORS, GENASYS L.C. 6 CADILLAC DC STS V8 6 FOUR-DOOR SEDAN (26,29,48,68) 7 ACTIVE (MANUAL) BELTS W/DRIVER & PASSENGER INFLATABLE RESTRAINTS (FRONTAL & SIDE). REAR PASSENGER INFLATABLE RESTRAINTS (SIDE) A ENG OPT - LH2 DISP - 4.6L CYL - V8 FUEL SYS - SFI DIV - 6 PROD IN - U.S. 4 CHECK DIGIT 5 2005 MODEL YEAR 0 LANSING - GRAND RIVER MI 233481 СЕРИЙНЫЙ НОМЕР 192 TRIM COMBINATION,BLACK/EBONY LEATHER 19I INTERIOR TRIM COLOR BLACK/EBONYINTERIOR TRIM,EBONY 1SK PACKAGE - OPTION 10 OPTION PACKAGE #10 OPTION PACKAGE #10 67U EXTERIOR COLOR,LT TARNISHED SILVER MET (04)EXTERIOR COLOR,PRIMARY 6SG COMPONENT FRT LH COMPUTER SEL SUSP (6SG) 7SG COMPONENT FRT RH COMPUTER SEL SUSP (7SG) 8HC COMPONENT RR LH COMPUTER SEL SUSP (8HC) 9HC COMPONENT RR RH COMPUTER SEL SUSP (9HC) A26 WINDOW,UNITED KINGDOM AND EUROPEAN GLAZING(EXPORT) A45 MEMORY SEAT ADJUSTER, MIRROR, POWER, DRIVER & ENHANCED MEMORY PERSONALIZATION A82 RESTRAINT SYSTEM,HEAD(EXPORT) AL2 CONTROL SEAT, POWER LUMBAR AP9 NET,CONVENIENCE AQ9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,RECLINING AU8 LOCK CONTROL REMOTE ENTRY, SPECIFIC FREQUENCY AX4 RESTRAINT SYSTEM,FRONT AND REAR SEAT,MANUAL(EUROPEAN) AY0 RESTRAINT SYSTEM SEAT, INFLATABLE, DRIVER & PASS, FRT SIDE, ROOF SIDE B20 ORNAMENTATION,INTERIOR(LUXURY) B57 ORNAMENTATION,EXTERIOR TRIM(DELUXE) BAG PARTS PKG EXPORT CE1 WIPER SYSTEM WINDSHIELD, PULSE, MOISTURE SENSITIVE CE4 WASHER,HEADLAMP,HIGH PRESSURE CJ2 HVAC SYSTEM AIR CONDITIONER FRT, AUTO TEMP CONT, AUX TEMP CONT CZ3 COUNTRY RUSSIA DD8 MIRROR,INSIDE,REARVIEW,TILT,AUTOMATIC,LIGHT SENSITIVE DL7 MIRROR O/S LH & RH, REMOTE CONTROL, ELECTRIC, HEATED POWER FOLDING, COLOR DT4 ASH RECEPTACLE AND CIGARETTE LIGHTER EXP EXPORT - I.E.S. EXPORT I.E.S. F55 CHASSIS CONTINOUSLY VARIABLE REAL TIME DAMPING MAGNETO RHEOLOGICAL FE3 SUSPENSION SYSTEM,SPORT G80 AXLE,REAR,POSITRACTION,LIMITED SLIP GU6 AXLE,REAR,3.42 RATIO IL2 TRIM,INTERIOR DESIGN JE5 BRAKE SYSTEM PWR, ANTILOCK, FRT & RR WHL JJA PT DRESS SUBASSEMBLY INSTALLED (MODULAR OPTIMIZATION METHOD ONLY) JNG PROP SHAFT, PAINTED K14 FILTER AIR, AUTO RECIRCULATING K59 CRUISE CONTROL AUTOMATIC ADAPTIVE KA1 HEATER - SEAT KA3 HEATER ENG BLOCK - 220 VOLT KG4 GENERATOR 150 AMP LH2 ENGINE GAS, 8 CYL, 4.6L/(281 CID), SFI, V8, DOHC, HO, ALUM, GM M22 TRANSMISSION AUTO 5 SPD, HMD, 5L50-E, ELECTRONIC, O/D N05 LOCK,FUEL FILLER CAP N31 STEERING WHEEL HEATED N87 WHEEL 18 X 8, ALUMINUM NT4 EMISSION SYSTEM EEC 05 NV7 STEERING,POWER,VARIABLE EFFORT Q12 TIRE ALL P235/50R18 FRT & P255/45R18 RR R6A CONTROL-SALES ITEM NO. 1 R7K CONTROL SALES ITEM NO. 36 T43 SPOILER,REAR T62 LIGHTING DAYTIME RUNNING ----DELETE T79 LAMPS,REAR FOG TR7 HEADLAMPS CONTROL LEVELING SYSTEM, AUTOMATIC TT8 HEADLAMPS HIGH INTENSITY DISCHARGE, RH RULE OF ROAD U19 SPEEDOMETER,INSTRUMENT,KILOMETERS PER HOUR U30 CLUSTER INST, TACH, CLOCK UA2 THEFT DETERENT SYS EXPORT SPECIFIC UJ9 INDICATOR, LOW TIRE PRESS,TIRE PRESS MONTORING SYSTEM(TPM) UV6 DISPLAY,HEADUP UX8 SPEAKER SYSTEM 8, DELUXESPEAKER SYSTEM 8, DUAL F/D MTD, DUAL RR DRS, DUAL MIRROR PATCH CTR I/P, PKG SHELF, AMPLIFIER V08 COOLING SYSTEM,HEAVY DUTY V4X MODEL CONVERSION GMX295, STS V8 V76 HOOK,FRONT TOW V78 VEHICLE STATEMENT(DELETE)(EXPORT) V92 TRAILER PROVISIONS VC5 LABEL - SHIPPING, EXCEPT US, US POSSESSIONS, OR JAPAN LABEL VH5 PLATE,VEHICLE IDENTIFICATION(EXPORT) VJ2 LABEL, EXPORT HEADLAMP ADJUST VJ4 LABEL, EXPORT CHILD SEAT LOCATION VL2 LABEL, SPARE CAUTION, COMPACT SPARE VL4 LICENSE PLATE,FRONT MOUNTING PACKAGE EEC VP6 NOISE LEVEL CONTROL VR5 PROVISIONS,SLOW VEHICLE WARNING TRIANGLE MOUNTING XA7 WASHER NOZZLES, HEATED, WINDSHIELD YQ2 INFOTAINMENT SYSTEM 010
  10. Ну правильно, он и спрашивал про ДВС от Эски, и дал VIN от Эски.
  11. Я могу привезти из Штатов без проблем (хоть Eibach, хоть Hotchkis), подождать только придётся.
  12. Там есть и другая, большая проблема - прога может быть кривая, и она не будет нормально фильтровать машину по VIN номеру. У меня знакомый где-то раздобыл/скачал, и в итоге - она ему пишет не правильно номера, выдаёт сразу несколько разных номеров, какие-то VIN вообще не видит, и т.д. Решишь подсказать номерок кому, а дашь не правильный, или привезёшь сам не ту запчасть - вот хреновая ситуация то получится. Да и прога 13-го года, уже давно устарела, т.к. много номеров уже сменилось с того времени.
  13. Ну, для "Тимлфей" бесплатно, т.к. у меня просто была прога открыта, скопировал да выложил.
  14. VIN:1G6DC67A560142530 RPO Код Описание 1SK PACKAGE - OPTION 10 OPTION PACKAGE #10 OPTION PACKAGE #10 323 TRIM COMBINATION LEATHER, MED DK CASHMERE (3) (04) 32I INTERIOR TRIM MED DK CASHMERE (04) 41U EXTERIOR COLOR,PRIMARY,BLACK 6SC COMPONENT- COMPUTER SELECTED, SUSPENSION 7SC COMPONENT- COMPUTER SELECTED, SUSPENSION 8HC COMPONENT RR LH COMPUTER SEL SUSP (8HC) 9HC COMPONENT RR RH COMPUTER SEL SUSP (9HC) A26 WINDOW,UNITED KINGDOM AND EUROPEAN GLAZING(EXPORT) A45 MEMORY SEAT ADJUSTER, MIRROR, POWER, DRIVER & ENHANCED MEMORY PERSONALIZATION A82 RESTRAINT SYSTEM,HEAD(EXPORT) AL2 CONTROL SEAT, POWER LUMBAR AP9 NET,CONVENIENCE AQ9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,RECLINING AU8 LOCK CONTROL REMOTE ENTRY, SPECIFIC FREQUENCY AX4 RESTRAINT SYSTEM,FRONT AND REAR SEAT,MANUAL(EUROPEAN) AY0 RESTRAINT SYSTEM SEAT, INFLATABLE, DRIVER & PASS, FRT SIDE, ROOF SIDE B20 ORNAMENTATION,INTERIOR(LUXURY) B57 ORNAMENTATION,EXTERIOR TRIM(DELUXE) BAG PARTS PKG EXPORT CE1 WIPER SYSTEM WINDSHIELD, PULSE, MOISTURE SENSITIVE CE4 WASHER,HEADLAMP,HIGH PRESSURE CJ2 HVAC SYSTEM AIR CONDITIONER FRT, AUTO TEMP CONT, AUX TEMP CONT CZ3 COUNTRY RUSSIA DD8 MIRROR,INSIDE,REARVIEW,TILT,AUTOMATIC,LIGHT SENSITIVE DL7 MIRROR O/S LH & RH, REMOTE CONTROL, ELECTRIC, HEATED POWER FOLDING, COLOR DT4 ASH RECEPTACLE AND CIGARETTE LIGHTER EXP EXPORT - I.E.S. EXPORT I.E.S. F55 CHASSIS CONTINOUSLY VARIABLE REAL TIME DAMPING MAGNETO RHEOLOGICAL FE3 SUSPENSION SYSTEM,SPORT GU5 AXLE,REAR,3.23 RATIO IL3 TRIM,INTERIOR DESIGN JE5 BRAKE SYSTEM PWR, ANTILOCK, FRT & RR WHL MV3 TRANSMISSION AUTO 5 SPD, HMD, 5L50-E PTU , ELECTRONIC, O/D MX7 MERCHANDISED TRANS AUTO PROVISIONS, O/D, AWD (ALL WHEEL DRIVE) N05 LOCK,FUEL FILLER CAP N31 STEERING WHEEL HEATED N87 WHEEL 18 X 8, ALUMINUM NT4 EMISSION SYSTEM EEC 05 NV7 STEERING,POWER,VARIABLE EFFORT PB4 LOCK KIT,ALUMINUM WHEEL Q12 TIRE ALL P235/50R18 FRT & P255/45R18 RR R6A CONTROL-SALES ITEM NO. 1 R7K CONTROL SALES ITEM NO. 36 T2J ORNAMENTATION,INTERIOR,EXPORT UNIQUE REQUIREMENTS(EXPORT) T43 SPOILER,REAR T62 LIGHTING DAYTIME RUNNING ----DELETE T79 LAMPS,REAR FOG TR7 HEADLAMPS CONTROL LEVELING SYSTEM, AUTOMATIC TT8 HEADLAMPS HIGH INTENSITY DISCHARGE, RH RULE OF ROAD U19 SPEEDOMETER,INSTRUMENT,KILOMETERS PER HOUR U30 CLUSTER INST, TACH, CLOCK UA2 THEFT DETERENT SYS EXPORT SPECIFIC UJ9 INDICATOR, LOW TIRE PRESS,TIRE PRESS MONTORING SYSTEM(TPM) UV6 DISPLAY,HEADUP UX8 SPEAKER SYSTEM 8, DELUXESPEAKER SYSTEM 8, DUAL F/D MTD, DUAL RR DRS, DUAL MIRROR PATCH CTR I/P, PKG SHELF, AMPLIFIER V08 COOLING SYSTEM,HEAVY DUTY V4X MODEL CONVERSION GMX295, STS V8 V76 HOOK,FRONT TOW V78 VEHICLE STATEMENT(DELETE)(EXPORT) V92 TRAILER PROVISIONS VC5 LABEL - SHIPPING, EXCEPT US, US POSSESSIONS, OR JAPAN LABEL VG1 PROTECTOR UNDERHOOD COMPOUND, CORROSION PREVENTIVE, WATER BASED, CLEAR,EXPORT VG9 PROTECTOR WAX,EXT BODY(EXPORT) VH5 PLATE,VEHICLE IDENTIFICATION(EXPORT) VJ2 LABEL, EXPORT HEADLAMP ADJUST VJ4 LABEL, EXPORT CHILD SEAT LOCATION VL2 LABEL, SPARE CAUTION, COMPACT SPARE VL4 LICENSE PLATE,FRONT MOUNTING PACKAGE EEC VP6 NOISE LEVEL CONTROL VR5 PROVISIONS,SLOW VEHICLE WARNING TRIANGLE MOUNTING XA7 WASHER NOZZLES, HEATED, WINDSHIELD YQ2 INFOTAINMENT SYSTEM 010 JJA PT DRESS SUBASSEMBLY INSTALLED (MODULAR OPTIMIZATION METHOD ONLY) JNG PROP SHAFT, PAINTED K14 FILTER AIR, AUTO RECIRCULATING K59 CRUISE CONTROL AUTOMATIC ADAPTIVE KA3 HEATER ENG BLOCK - 220 VOLT KA6 HEATER,RR SEAT KB6 HEATER SEAT, COOLING, FRT KG4 GENERATOR 150 AMP LH2 ENGINE GAS, 8 CYL, 4.6L/(281 CID), SFI, V8, DOHC, HO, ALUM, GM
  15. Если пред вытащить, то ошибка точно будет. Если просто разъём с него снять, то вроде не зажигает (но могу ошибаться).
